Wanted: Tunnel Rubber Trim and Foam Pad - Defender Source
Old May 12th, 2014, 01:09 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
These are the two factory parts used on auto Defenders to cover the tunnel, same as the manual parts but with just one hole for the hi / lo lever, not the shifter.
Also may consider another stock rubber trim boot that I can modify to cover the shifter hole with thick rubber. This is going under the console so it doesn't need to be pretty. Just needs to stop the heat/draft.
rubber, wanted
D-90 dash pad, rear seat belt, trim PMKColorado Wanted 0 July 5th, 2013 09:45 AM
NOS NAS Rubber Tunnel Covers and NAS Insulated Floor Mats SafariHP The Vendors Loft 17 January 27th, 2013 01:45 AM
Defender 90/110 Exmoor trim front bottom and headrest seat cover includes foam New Shop On Broward For Sale - Parts 8 January 23rd, 2013 09:10 AM
Rubber Tunnel Cover and other pieces bstraw Wanted 0 March 10th, 2009 08:50 PM
Rubber tunnel cover Overlander Defender Technical Discussions 1 June 16th, 2008 11:08 AM
