Wanted: series air cleaner designed for snorkel - Defender Source
Old September 28th, 2015, 11:40 PM
modrover's Avatar
modrover
Michael
1971 Series IIA 109 Station Wagon
Thumbs up Wanted: series air cleaner designed for snorkel
Looking for one of those series oil bath air cleaners designed for snorkels. This was a factory option. They have the intake top closed off with the intake coming off the side and it fits in the stock series air cleaner location. I may be interested in the whole factory series snorkel kit if you have it, but I would be thrilled with just the air cleaner part itself. Please PM me with what you've got and what you think is fair for it. Thanks
Boomshanka
1971 IIA 109 Station Wagon
1967 IIA 109 Pickup
Old September 29th, 2015, 08:40 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
You could also try Ike at Pangolin4x4 or he might know someone that would be willing to sell from their stash. Remember seeing a crated kit for sale on Ebay UK while back. Went for crazy money. PB Blanchards, Dunsfold or the operation out of Cyprus might still have some. They sell out of ebay.co.uk.
Old September 29th, 2015, 10:20 AM
modrover's Avatar
modrover
Michael
That's what I was afraid of... ridiculous prices. :D Probably why I don't see these pop up.
My 109 is a survivor daily driver so it's hard to justify "restoration" or "rare" pricing for my needs. Thank you for the suggestions... I'll look into those. Might get lucky!
I'm still hoping someone might have one tossed in a corner they'd sell for deal... I mean... "No one puts Baby in a corner."
Cheers!
Boomshanka
1967 IIA 109 Pickup
Old September 29th, 2015, 10:24 AM
Stole image off Dare britannica web site
Old September 29th, 2015, 10:35 AM
Those kits were 400 bucks when they were still available new.
You'd be better off going with the early 90/110 4 cylinder (non-tdi) style round filter that uses a paper element and should fit in the same mount albeit with some mods.
Or you can look for the ones that came on Series 1's that had the exit coming off the side.
But those are usually spendy too.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 29th, 2015, 11:02 AM
modrover's Avatar
modrover
Michael
That's the kit... and there's that air cleaner. There's a note on that web site about only being offered to preferred customers... guess that'll rule me out. :D
------ Follow up post added September 29th, 2015 10:07 AM ------
It's interesting that you bring that up... I have been contemplating using a different air cleaner for my snorkel setup. I was hoping to score a stock series cleaner, but it's starting to sound too pricey for my beer budget. I'll look into those 90/110 4cyl non-tdi air cleaners. I'm not opposed to using a paper filter style either. I just want a nice clean setup with good air flow.
So... with that... I might be interested in above mentioned air cleaner as well.
Boomshanka
1967 IIA 109 Pickup
Old September 29th, 2015, 12:18 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Let me know if this is what you might be interested in. This comes out of a low mileage early 83 110. It has a little surface rust that will clean up easily. The filter is new. I can take additional pics if you are interested in seeing them.
Old September 29th, 2015, 01:18 PM
modrover's Avatar
modrover
Michael
Thank you for the offer. It looks like intake exits out the top... might be a tight fit (even with an elbow) utilizing the stock series lock-down strap. There isn't much room between the lock-down strap and hood when closed so it might be an issue. I'll keep you in mind if I can't figure out an in/out from the side filter canister. Again, I appreciate the offer though.
Boomshanka
1967 IIA 109 Pickup
Old September 29th, 2015, 02:03 PM
In the photo above, the hose from the filter to the intake is on backwards. The tight elbow on the hose connects to the top of the filter housing. It should be able to work on a Series, but you would need to remove the complete stock assembly and modify the legs.
Old September 29th, 2015, 02:13 PM
Wonder if an air cleaner from a tractor would work. Typically oil bath. But size?
This is the idea: http://www.tractorpartsinc.com/ford_..._2830_prd1.htm
Old September 29th, 2015, 03:43 PM
TRG
David Gage
67 Series 2a
If all else fails and you want to go paper, you can use the K&N Apollo system. This is what I'm using to go from the Isuzu 2.8 TD to the snorkel on mine.
K&N Apollo Universal Closed Air Intake Systems
Old September 29th, 2015, 03:49 PM
1of40's Avatar
1of40
1of40
John, is absolutely correct. I was recently playing with the cleaner's hose to see if I wanted to try and work it into my 200tdi swap.
Old September 29th, 2015, 06:28 PM
airbornrover
William Skidmore
SIII 109 SW
Why not just close off the intake on the series filter canister and cut a hole then weld a section of pipe and the side and bam you have your snorkle air filter canister?
Old September 29th, 2015, 06:30 PM
87 D110 (Ruby)
got it
Old September 29th, 2015, 06:58 PM
scrubs
henery
1974
Have you looked at a jaguar air cleaner?
iirc it's the coup style
Old September 29th, 2015, 07:03 PM
modrover's Avatar
modrover
Michael
I may end up going this direction if I cannot locate a stock snorkel type air cleaner. Modifying isn't out of the realm, but it would sure nice to not have to.
------ Follow up post added September 29th, 2015 06:04 PM ------
No, I'm not familiar with that. What year would have used this? Thank you
------ Follow up post added September 29th, 2015 06:05 PM ------
got it
I've replied back to your PM... in hopes it's the type I'm looking for. Thanks
Boomshanka
1967 IIA 109 Pickup
Old September 29th, 2015, 07:10 PM
scrubs
henery
1974
I ebayed it yesterday n looks close to what you are looking for
Old September 29th, 2015, 07:13 PM
They way the Series LR filter is designed, it would be hard to do that and have it
a: work properly
b: not look like shit
c: fit under the bonnet (with the bonnet closed, smartass)
That's why LR made the snorkel-y one shorter than the factory one.
Present:
1987 RRC- "Chewy 2"
Past:
Old September 29th, 2015, 07:21 PM
modrover's Avatar
modrover
Michael
a: work properly
I have thought the same... in order for the elbow to have clearance with lockdown strap and bonnet closed... the top would need to be cut open to allow the metal elbow to recess down far enough to be welded... then the top would need to cut/welded around this elbow. Yes... I imagine it would look something along the lines of Frankenstein's monster. It certainly can be done, but that's a lot of time and such. Let's hope a factory one shows itself.
Boomshanka
1967 IIA 109 Pickup
series, snorkel, wanted
Snorkel Air Cleaner The Dro Wanted 2 December 5th, 2012 09:44 PM
Need NAS 90/110 Air Cleaner Air Horn Wolf Fabrication Wanted 7 December 28th, 2009 06:43 PM
3.9L Air Horn / Air Cleaner Cover Wolf Fabrication Wanted 0 November 3rd, 2008 08:10 PM
Wanted: Air Cleaner Assembly kiphartzell Wanted 2 September 15th, 2006 12:43 AM
Air box (air cleaner) TDI Guy Wanted 3 September 4th, 2006 11:41 PM
