Wanted - RR diffs for my Series III - Defender Source
Old February 21st, 2012, 02:24 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
So, I hear that early RR diffs will fit my series and give it much better highway gearing. If anybody has a set that is gathering dust, let me know.
1st gear might even be usfull after the swap, because I normally just start off in 2nd.
Old February 21st, 2012, 03:25 PM
winn442's Avatar
winn442
Winn Bearden
Think I have a set of 10 splines in storage, I'll check when I'm on that side of town, probably tomorrow.
Winn Bearden
Old February 23rd, 2012, 07:45 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I thought the only difference between the older Rangies (87-90) and neweer ones (91-95) was that they were 10 spline instead of 24 spline.
Are you looking for earlier than 87?
John C.
Old February 23rd, 2012, 07:55 AM
red64chevelle
Daniel Smith
From what I have gathered using the web, the early (older than 87) RR diffs are still 10 spline but with a 3.54:1 ratio vice the 4.71:1 ratio on series trucks.
I guess I should have specified this.
Old February 23rd, 2012, 07:57 AM
JohnC
The stock diffs on all 87-95 RRC and 94-99 DI are 3:54:1 (I believe).
John C.
Old February 23rd, 2012, 09:33 AM
red64chevelle
Daniel Smith
But the pre-87's are also 10 spline. My series is a pavment queen, so I don't want to spend the effort or money to convert to a 24 spline axle.
Old February 23rd, 2012, 09:38 AM
carlosz's Avatar
carlosz
Carlos
I have a 92 rr m stripping so the whole front and rear axle assemblies could be made available.
Im keeping engine and trans, the rest is in limbo on if I want to store or not.
technically it is a rolling chasis as the inside is/ was gutted when purchased as a parts truck and I have peeled all the outside sheet metal...(fenders, doors, quarter pannel, hood).
the steering box is sold.
if interested let me know, you can have it for a decent offer the main caviat... Im in stafford Va
so transport an issue...
Old February 23rd, 2012, 09:48 AM
red64chevelle
Daniel Smith
Thanks for the offer, but I really only want the early diffs. My defender is layed up while I swap in a 300TDI, so I don't have any space for a roller.
Old February 23rd, 2012, 10:02 AM
JohnC
I have a diff or two (10 spline, 3:54) from a Rangie. I'll double check tonight and let you know.
John C.
Old February 23rd, 2012, 10:31 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
RR are 10 splines up till 1993. 1994 they switched to 24 spline.
Old February 23rd, 2012, 11:19 AM
Matt223081's Avatar
Matt223081
Matthew Scanlon
84 D90 200TDI
I have a set of 10 spline diffs out of my 84 d90
Old February 23rd, 2012, 11:30 AM
red64chevelle
Daniel Smith
PM me with what you want for them. I am hoping for a local pickup to prevent giving all of my money to a shipping company.
Old February 23rd, 2012, 11:41 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Call Paul Grant. He should have some. He is by you too so shipping will be cheap of you can pick them up.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 23rd, 2012, 07:15 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I have a set that I will sell. Not to far from you. PM sent
Patches are for Pirates and pants, not a bulkhead and chassis!
Old February 23rd, 2012, 07:29 PM
Mid 1993 they switched to 24 spline.
Old February 23rd, 2012, 07:38 PM
red64chevelle
Daniel Smith
Matt is sending me a set. Thanks for the other offers.
Old February 24th, 2012, 05:26 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You don't need the whole diff, the RR R&P will fit the Series carrier. I put a set in an 88 I converted to a Perkins 4.203 in '82.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 24th, 2012, 01:14 PM
red64chevelle
Daniel Smith
I forget the years on the the series trucks, but if you don't have a fill plug on the axle housing, you will need to ad one, or swap the 3.54 diff into the series 3rd member housing that has the fill plug.
-Jeff
Thanks for the advice. I will take a look at it and probably just add a fill plug. Is there any problem with just drilling and tapping a hole in the 3rd member? People do it with ARB's and such. I can then not weld on the housing and do the whole thing on the bench. I can just use a pipe plug to seal the hole.
Old February 24th, 2012, 01:25 PM
carlosz's Avatar
carlosz
Carlos
shucks... for that matter and if you are willing to overhaul and set up your current carrier housings, I have two sets of 3:54.1 ring and pinion left from a 4:11.1 conversion.
let me have $50.00 for both plus shipping they are yours... they are just ring and pinion gear sets thou. front and rear and you get to keep all your other internals and the carrier housing.
Old February 24th, 2012, 04:43 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Are you sure about this? Im pretty sure a RR R&P will not fit the series carrier. you will have to use the carrier from the RR as well and put the R&P and carrier in the Diff.
You can put the 4.7 series gears on the 3.54 carriers with a spacer ring but pretty sure it wont work the other way.
85 D110 3.5 3 DR
diffs, fs, series, series iii
1974 Registered Series III Hybrid-RHD wlykes For Sale - Vehicles 5 July 23rd, 2009 12:45 AM
1974 III Series 88 SW Prototype For Sale Nil For Sale - Vehicles 0 August 10th, 2005 02:39 PM
Stage 1, series III pickup wanted m.olivares Wanted 0 February 14th, 2005 01:50 PM
$100,000 LR Series III 1964 paulb Misc. Chit-Chat 5 September 15th, 2004 01:09 PM
