Wanted: Range Rover Classic...again - Page 5 - Defender Source
Old March 31st, 2016, 12:02 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by Kevin88RRC View Post
I'm guessing it's gonna go for more than his price range.
I take responsibility for not being more clear I guess. My budget is 3K-6K. I assume there are some classics that are out there that fit the bill in that budget.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old March 31st, 2016, 04:02 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
I left my sunroof open for a week about 2 weeks ago... Damn lucky it didn't rain (Texas, so we're good)... Everything works, and the ski jump didn't warp. Just proof that I need to drive it more often so that crap doesn't happen.
Have you tried PT in Indiana for a truck? I'm not sure if he is on the forum, but he's my RRC go-to.
Rovers, Guns, and Airplanes... Willing to share my Ramen Noodle Recipes!
'95 RRC CountyLWB - dripping all over central TX
'83 110 HCPU - in piceces, all over central TX
'90 RRC Truggy - loud and proud
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old March 31st, 2016, 04:19 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I vote for Chris's RRC especially since he dropped the price to $3k. Take care of the laundry list & you're still in budget. Plus it has a known working transmission.
http://www.defendersource.com/forum/...swb-68839.html
Old March 31st, 2016, 04:58 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
Luckily for the buyer of this parts truck the seller is offering a payment plan. Sunroof has been open for months so the rain has helped the Lucas electronics. And no I didn't waste any time going to look at this bargain, they sent me pictures of the heap.
Attachment 146375
any more pictures of this heap? is it pretty crusty? Seems like that C pillar isn't all that bad
Old March 31st, 2016, 05:07 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I've talked to Chris, thanks.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old April 3rd, 2016, 05:17 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Here you go. Not mine, just ran across it.
1987 Range rover classic diesel
1987 Range rover classic diesel - $6500
1987 land rover range rover
VIN: sallhame8ea306059
I recently imported from Italy Classic RR with the original 4 cyl 2.5 turbo diesel VM engine with 5 gears manual transmission , to find out that California DMV will not let me register it !? yes I thought too that a 25 years old diesel could be imported in California without problem ... obviously not at least for the guy at DMV handling my case.
I have the US custom import paper in my name , the official De-registration document from the Italian registry .
If you are out of California you should be able to register it (please check with your DMV) , or if you just want to use the car for off roading , rock crawler or on a ranch . It is in good original shape ,not perfect but ok considering the age , the heads have been redone 8,000 miles ago , the car has approx. 109K miles (175K KM) ,
the clutch slip a bit on high gear , I have the new spare parts to replace it along with the main engine seal and the throw out bearing , here are a few cons:
there is a 4" tear in the driver seat
the battery icon light on the dashboard is blinking but the alternator is putting out 14.3 V. and the batteries (2) are always full
The cabin lights are always on so I removed the bulbs ( there may be a on/off switch but I cannot find it)
The auto windows all work depending on how good you are in massaging the switches
There is air conditioning gear under the hood but it does not seem to work ? I cannot see any on /off comands in the cabin.
the headliner is starting to fail
there is a sweat of diesel from the tank sender unit (gasket?)
as you can see from the picture the hood insulation is damaged in the center
there are 2 rubber cushions on the rear axle stabilizer rods that needs replacement
there is one rust spot in the rear drivers side door just above the wheel well , there is some (very little ) superficial rust on the metal plate /guard under the fuel tanks a bit here and there
with that said , this is a 28years old car in original condition , it is a very good candidate for and easy restoration or just use it like that with the minor imperfections
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old April 12th, 2016, 06:56 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Still looking. Have a couple leads, but would really like to expand the pool.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old April 15th, 2016, 10:10 AM
1992 Range Rover NEW INFO ADDED
1992 Range Rover NEW INFO ADDED - $4000 (STAMFORD)
odometer: 172000
Great driver or restoration. Solid Original 92 RR County.Westminster Grey exterior with matching interior.
The Good: Starts, runs, drives, stops. Paint in very good condition except faded on roof. All seats intact, with no rips or tears. Original carpet in decent shape. Dash has no cracks. Headliner intact and not sagging. No frame rot. Air suspension replaced with OME and Defender wheels, 275/75/16 Newish General Grabber AT2 tires. Elec windows function. Matching OEM sheepskin seat covers come with. Transmission shifts smoothly.
The Bad: Rust at lower tailgate, rear door latches and very small spot of passenger footwell. A/C non functional. Interior woodwork dried and worn. Seat heaters not functioning. Two exhaust manifold bolts snapped. (the easiest ones to reach, forward, driver side)
Additional photos will be linked as soon as I can figure it out.
Old April 15th, 2016, 01:57 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
odometer: 172000
Thanks. I talked to the guy the day he posted the ad, still cannot get him to send any pics of the rust areas.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old April 23rd, 2016, 09:44 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
No longer perusing a RRC. White 95 inbound. Thanks for everyone's help and input along this journey. I have some hilarious stories from talking with sellers about their classics.
Never trust someone that says "oh there is zero rust on my truck, come buy it, it's a steal". Then they have stop sign welded to floor. I really do feel for noobs looking with all the bullshitters out there.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old April 23rd, 2016, 09:46 AM
Ray_G's Avatar
Ray_G
Ray Gerber
But I bet the stop sign wasn't rusty! Besides, everyone knows it is only janky if you use license plates and drywall screws to patch rust holes.
Old April 23rd, 2016, 09:50 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I have 2 VIN's and unlimited carfax via license plates if anyone is seriously considering a vehicle. Expires May 5th. PM me.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old April 23rd, 2016, 10:24 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I always hang on to my old plates for floor repair BUT I only use stainless screws from Nakatanenga...
Congrats on the purchase Matt.
Rent my
classic, range rover, wanted
Wanted: Range Rover Classic SWB WeBeCinYa Wanted 81 November 25th, 2014 09:14 PM
Wanted: 1995 Range Rover Classic littlehandegan For Sale - Vehicles 5 September 14th, 2014 05:44 PM
FOR SALE: 1989 Land Rover Range Rover Classic (lifted) Rovercox For Sale - Vehicles 33 May 28th, 2014 09:44 PM
1995 Land Rover Range Rover Classic SWB NRO For Sale - Vehicles 4 April 3rd, 2011 10:18 PM
