Wanted: One wheel spacer - D-90 - Defender Source
Old December 26th, 2006, 07:36 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I need one wheel spacer to space the spare out from my newly installed tire carrier. I'm running 235/85R16's on factory alloy wheels and the side of the tire is rubbing on the tire carrier I just installed. Anybody got a broken set - it doesn't even need to have five good lugs on it.
Old December 26th, 2006, 10:25 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Screw some nuts (or half nut) before puting spare...
- Charles Eames
Old December 27th, 2006, 04:07 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
The studs on the tire carrier aren't really long enough - that's my temporary solution but I'd like to get my hands on one of the 30mm spacers like Rovers North sells with one screwed up stud so I could replace that stud with a pin that would be drilled for a padlock.
Old December 27th, 2006, 04:34 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Can you just weld on longer bolts?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 27th, 2006, 06:18 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Hate to mess up the nice powdercoat job on the rack - also don't want to take it all back apart again now that its adjusted. I can make a spacer - I have access to machine tools - just trying to take the easy way out.
Old December 27th, 2006, 06:33 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The other solution is to install the new spare wheel carrier
that are used on early defenders, it looks like the one of
the discovery.
I have one catching dust, but i'm a little far away .
- Charles Eames
Old December 28th, 2006, 12:22 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
I think I have one, I'll check tonight.
90, ac, d-90, wheel, wheel spacer
Wheel spacer help needed isleofbones Defender Technical Discussions 11 April 19th, 2009 08:17 PM
1" wheel spacer - borrow Jase Defender Technical Discussions 0 July 16th, 2005 05:23 PM
255/85 wheel spacer experience D90user Defender Technical Discussions 6 July 13th, 2005 11:12 PM
Roll Cage Wanted for my 95 Defender 90 edducati Wanted 6 July 28th, 2004 03:34 AM
D 90 wanted Weaver Wanted 1 July 10th, 2004 11:18 PM
