Wanted OEM flush mount antenna...or cap for antenna hole - Defender Source
Old April 13th, 2010, 01:41 AM
mfj20th's Avatar
mfj20th
Jake
1997 D90 Wagon
Gents
Anyone have a good idea to cap the antenna hole?
I'm relocating my am/fm antenna to a fiberglass whip that will mount to my ARB front brush bar...The factory antenna will go close to flush in the full down position, my aftermarket wont....
Or, if anyone has a cap solution, in rubber/plastic--that'd be ideal...
If you have a solution or a bent antenna to sell...
I'm game...
Thx much
Peace,
MJ
Old April 13th, 2010, 07:46 AM
Rugbier's Avatar
Rugbier
Gustavo
MJ, do you have 5bars plates on your wings? if you do simply put a rubber groomet on the wing hole and replace the 5bars with a hole-less one.
If not, do the same and place a new set
just a suggestion
NO SIGNATURE
Old April 14th, 2010, 08:21 AM
mfj20th's Avatar
mfj20th
Jake
1997 D90 Wagon
bump
mount, oem
Rover Rust hole, not mine, nor do I know the owner. But if you need one. rgrrvr The Flea Market 6 May 28th, 2008 10:52 PM
OEM Antenna or Replacements boshea Defender Technical Discussions 14 January 18th, 2006 01:15 PM
Wanted: OEM Safari Rack for ST D90 jam90 Wanted 1 August 22nd, 2005 09:21 PM
Wanted: OEM rear Diff gaurd Northface Wanted 3 February 19th, 2005 08:21 PM
Antenna Wanted For 95 D90 Rockhead12 Wanted 2 January 12th, 2005 06:12 PM
