Wanted: Mean Green Starter - Defender Source
Old December 29th, 2010, 03:12 AM
Starter is sticky. Not sure If I had a sticky starter before it was sub 20 degrees, but now the starter sucks (cold out!!). Starts fine when it's in the garage; otherwise sucks. Should take it apart and check the brushes, but figured id get this out there.
Want a Mean Green before I look OEM new.
Got one? Looking to spend around $250ish used.
This puppy loves the snow, so make her dreams come true.
Old December 29th, 2010, 03:14 AM
Bump.
Old December 29th, 2010, 09:48 AM
specops1526's Avatar
specops1526
Beluga '97 90
Horsey, seriously? First you drive right behind a salt truck and now you want to put a used part in your truck? If I were you I'd get a new part. Why risk the chance with a used one that could possibly fail soon after you drop it in?
Are you sure it's the starter? What are the symptoms?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
start, starter
Series II Starter wanted ROVERMAN1 Wanted 0 August 21st, 2010 07:39 PM
Mean Green Starter $100.00 plus shipping. wcampbel@nas.edu For Sale - Parts 3 August 3rd, 2010 06:35 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
