Wanted Info On Webasto replacement screws? - Defender Source
Old February 15th, 2016, 05:40 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
After bench testing a used Thermo top I bought last year and never installed, I discovered that screws on the inner chamber that holds the igniter/glowplug section to the main housing weren't
there! Damn. They are the same torx heads that are on the outer area, 4mm or so. Anybody know the exact specs so I don't have to tap these and can order from Macmasters etc?
I have checked all the parts lists catalogues and can't find the screw size listed. Been to hardware and HD etc. the threads are definitely special.
ID:	142456   Click image for larger version
ac, wanted, webasto
Webasto ThermoTop C and Webasto Fuel Pump flananuts For Sale - Parts 4 October 7th, 2015 09:08 AM
Wanted webasto airtop 2000 harness and/or heater control flananuts Wanted 0 January 13th, 2015 05:03 PM
1997 NAS 90 Front Brake Info Wanted don Defender Technical Discussions 6 January 25th, 2014 01:29 PM
Wanted plastic license plate screws evilfij Wanted 1 February 18th, 2009 01:27 AM
Rear Door Hinge Screws Rob Defender Technical Discussions 1 October 12th, 2003 06:46 AM
