Wanted: Flexplate for ZF4hp22 w/ 3.9 v8 - Defender Source
Old December 31st, 2015, 12:09 AM
RamblerRob
Rob Apps
1967 series 2a 109 NADA
I'm trying to find a flexplate, buttress ring and bolts from a disco 1 or range rover classic with a 3.9 v8.
I'll need to confirm bolt pattern so please be prepared to take a few simple measurements (something no ebay seller seems willing to do :/ )
Rob
Old December 31st, 2015, 07:00 AM
rovertrader's Avatar
rovertrader
Dale
Try these guys:
Land Rover Discovery I II Cup Holder Set Genuine Land Rover Bahama Beige | eBay
Old December 31st, 2015, 10:06 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I have all of that. What are you trying to match it to? The holes are all unevenly spaced so they only bolt on one way. Same unit fits all 3.9 and 4.2, and the bolt pattern is the same so it will also bolt up to a 4.0/4.6 if you were using a ZFhp22 behind it rather than a hp24.
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old December 31st, 2015, 10:32 PM
RamblerRob
Rob Apps
I just ended up buying one from ebay and hoping it works. according to part numbers the ones from the 3.9 differ from the 4.0 and later.
I'm mating up to a conversion crank adapter from marks4wd.
I'm looking for the following bolt pattern on the holes to bolt the flexplate to spigot or crank adapter
Opposing Holes: 10cm
Adjacent holes: 7.1cm
Spigot Diameter: 6.3cm
All measurement to hole centers.
The plate I have from a disco 2 (which shares a part number with 96-99 disco 1s) has 10.5 cm & 7.5cm with 8.4cm center hole.
I had a fellow on a different forum measure his range rover classic ('91 with a 3.9) and the pattern he had matched up, though i didin't have him measure the center holes
Old December 31st, 2015, 10:59 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
The reason the part number is different is because the hp24 used behind the 4.0/4.6 takes a totally different torque converter from the hp22. The crank adapter, spacer, flywheel/flexplate are all different between the two trannies, but the 6-bolt crankshaft pattern is still the same, just that the bolts are not evenly spaced. I've done several 4.6 swaps into RRCs so I know this firsthand.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old December 31st, 2015, 11:11 PM
RamblerRob
Rob Apps
I see where we are crossing wires here.. Landrover uses some confusing terminology. they also refer to the drive plate that the torque converter bolts to as a flexplate at times. So i dont need the flexplate/flywheel but the drive plate(also called a flex plate) that bolts to the torque converter on the outside holes and the flywheel aligning spigot on the inside.
Marks4wd kit uses a GM flywheel(on the back of a SBC or 262), bolted to the crank adapter (which replace the spigot) then bolted to the rover drive plate (for reference part #FRC7081... I hope!!) So its the bolt pattern on the driveplate I need to match up.
Apologies for the confusion
flex, v8, wanted
Late model chev v6 to ZF4hp22 RamblerRob Smaller Projects 15 September 27th, 2016 04:05 AM
Who'd got an early disco or range rover classic flexplate they can measure for me? RamblerRob Defender Technical Discussions 0 December 29th, 2015 10:41 PM
ZF4HP22 and LT230Q t/c RoverC For Sale - Parts 3 June 24th, 2008 08:30 PM
ZF4HP22 transmission question..... kiphartzell Defender Technical Discussions 9 December 28th, 2005 09:11 AM
fluid change on a ZF4HP22 D90_Camel Defender Technical Discussions 3 June 2nd, 2005 04:41 AM
