Wanted: Defender accelerator pedal assembly - Defender Source
Old March 6th, 2014, 02:20 PM
giftshopduane
Chris luciano
72 Series 3 88"
Sorting out my carb and throttle issues on my Series.. I would like to go with a Defender assembly
thanks
C
Old March 6th, 2014, 02:33 PM
No fitzky, unless you wish to dismantle it and bend it all different.
Do tell, what issues are you having that the rod linkage cannot work with? I have the original rod linkage on my 200 tdi. Had to make 2 new rods, but that was it.
Old March 6th, 2014, 02:37 PM
giftshopduane
Chris luciano
72 Series 3 88"
Looks like it could work for me... I am real talented with blunt objects and vices! Looks like it sucks so much less than the series pedal.
Old March 6th, 2014, 02:39 PM
giftshopduane
Chris luciano
72 Series 3 88"
I just need to start over fresh, my cable is too short, the arm is too long, can't get full throttle, its a jumble of parts. I have limited time and space to tear into it so I want my ducks in a row and just attack it.
Old March 6th, 2014, 02:49 PM
The flat vertical bend in the defender footwell is much greater in dimension than the series footwell. I tried to make one of those work and you have to cut off too much to get it to fit.
Old March 6th, 2014, 02:57 PM
giftshopduane
Chris luciano
72 Series 3 88"
Hmmmm, thanks. I'll look into it more.
Old March 6th, 2014, 04:00 PM
aka rover's Avatar
aka rover
ed angel
95 D90
I used the Series and had a cable made for my conversion . here is a few pics during mock up.
ID:	90834   Click image for larger version
Name:	008 - Copy.jpg
Name:	002 - Copy.jpg
ID:	90836   Click image for larger version
85 D110 3.5 3 DR
Old March 6th, 2014, 09:37 PM
giftshopduane
Chris luciano
72 Series 3 88"
Thanks Ed... mine just really sucks at the pedal side of it.. I am using a DiscoII cruise control cable housing, and a few other bits. It works I just want to start over.. the connection at the Carb is great, works well (ish) I'll sort it out.
ac, assembly, defender, wanted
WANTED NAS Defender rust is OK ron Wanted 24 September 9th, 2013 04:17 PM
Wanted: Titled Defender For Rebuild 2k7997tt Wanted 3 November 17th, 2009 02:30 PM
Roll Cage Wanted for my 95 Defender 90 edducati Wanted 6 July 28th, 2004 03:34 AM
Wanted 97 Defender Gray Jump Seats rbtrader Wanted 1 October 10th, 2003 10:29 PM
