WANTED D90 OME suspension - Defender Source
Old March 12th, 2016, 09:58 AM
hacksaw830
John Fields
72 Series III
I have an 89 D90 Im looking for a set of rear hd OME 2762 springs to match a set of fronts that I have. I am also looking for a set of OME shocks for the same truck.
Old March 12th, 2016, 10:16 AM
Call Zack at Rovers North. He can get you pretty much anything you desire for your Defender.
Old March 12th, 2016, 10:19 AM
hacksaw830
John Fields
72 Series III
Thanks but I'm lookjng for a used set. TQUOTE=javelinadave;722310]Call Zack at Rovers North. He can get you pretty much anything you desire for your Defender.[/QUOTE]
Old March 12th, 2016, 10:27 AM
Why used? They are cheap enough and they are ware items. Good luck with your hunt.
Old March 12th, 2016, 10:17 PM
I have a full set of Medium duty TF +2 springs for a 90.. in OME boxes for $100 and i'm sure they can be Rurr'd most of the way at Uwharrie Safari.. (or my wife may be headed down there soon)
If you don't have a lot in the rear, MD is the way to go.. unless you have an ARB bar and winch in the front.. then you want HD fronts and MD rears.. which is where i ended up.. just a thought..
In full disclosure - i switched to OME springs and steering stabilizer but kept the TF shocks.
If you want the TF Return to Center stabilizer its included for free (i hated it). The MD TF springs were not up to the ARB Bull bar, winch, and Hi-lift combo on the front. You should also add in D2 spring isolators as well..
95' D90 - daily driver..
90, d90, wanted
OME springs, shock turrets and stock suspension parts D90,D1,RRC Dano G. For Sale - Parts 5 June 11th, 2013 08:05 PM
problems leveling D90 with OME Suspension mrossi Defender Technical Discussions 21 January 15th, 2012 08:54 PM
OME suspension id kolvedic Defender Technical Discussions 1 August 15th, 2005 01:46 PM
OME suspension scubadanster Defender Technical Discussions 19 February 25th, 2005 09:37 PM
OME suspension, and tires huntahdefender Defender Technical Discussions 4 October 10th, 2003 04:14 PM
