Wanted: d-90 pitman arm, Defender Cross Rod End - Defender Source
Old September 25th, 2009, 02:52 AM
Blakesrover
Blake
Disco 1
Want to convert front end of D1 to fit d-90 steering components and replace damper from stock location. If there are any other parts I will need, please feel free to chime in
pitman arm, cross rod end, stock damper, and any misc. bolts and pieces.
Question: What is normally used to mount the damper on the frame? D90 has a welded on piece to accept the damper thread. Is there something aftermarket to accommodate that for the D1 frame mounted area?
Thanks.
~Blake
BPerry83@gmail.com
Old September 25th, 2009, 12:54 PM
Blakesrover
Blake
Disco 1
Smile
I'm planning on doing a damper relocation on the D1 and am looking for a D-90 pitman arm (steering drop arm) & cross rod eye end (P# RNE442)
I am almost positive those are the only parts I need but any odds and ends I might be missing please advise.
Thank you.
~Blake
BPerry83@gmail.com
I wanted to add this post as maybe the verbiage of pitman arm isn't used as is drop arm and also the PN's I could find to help.
Old September 25th, 2009, 01:28 PM
This may be an option for you...
http://solaros.com/smf_production/in...p?topic=3583.0
Old September 25th, 2009, 01:33 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Why not just go with RTE's (or any of the other vendor's) damper relocation kit? Likely easier in the long run.
Old September 25th, 2009, 03:09 PM
If you are inclined to weld onto your frame (and have access to a welder), I suspect I can cut off whatever mount piece you need from my D90 frame I have here for you.
charles
Old September 25th, 2009, 03:42 PM
Just bolt a piece of 3/8ths strap to the two holes.
Old September 25th, 2009, 08:38 PM
Blakesrover
Blake
Disco 1
Not a big fan on these types of applications.
HLC fab seems ok, but again not an application I'm looking for or the amount of money i'm willing to spend.
Not sure I want to weld on the frame but will look into the ability to bolt-in. I'll have to take a look again.
If anyone crosses over these parts, or a D-90 being parted out, please let me know.
~Blake
90, d-90
F/S 1995 Defender 90 ToddR For Sale - Vehicles 9 September 19th, 2016 06:09 PM
1994 Defender 90 - Hardtop and A/C silver_defender For Sale - Vehicles 4 August 14th, 2009 03:31 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
Wanted 97 Defender Gray Jump Seats rbtrader Wanted 1 October 10th, 2003 10:29 PM
