Wanted - Banjo Bolt for PS Pump - Defender Source
Old October 8th, 2015, 08:27 AM
LRover's Avatar
LRover
J. Michael McCaig
I need the banjo bolt that goes in the power steering pump high pressure output on 1983 -89 turbo diesel (19j). Evidently the bolt comes with a new pump only and mine has gone missing. I prefer not to buy a new expensive pump just to get the banjo bolt. See photo below. Thanks!
Old October 8th, 2015, 08:33 AM
Do you know what type thread it is?
------ Follow up post added October 8th, 2015 08:35 AM ------
If its metric, i source my fittings from Belmetric
https://www.belmetric.com/metric-ban...37oq115ltk0tj7
Mark Kellgren
KM4BOR
Old October 8th, 2015, 08:48 AM
Have a bolt that I would like to keep. But, I can measure it if that helps.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 8th, 2015, 09:29 AM
LRover's Avatar
LRover
J. Michael McCaig
The problem is I can't even see the internal threads unless I pull the pump off. If you could measure your bolt and figure out if the threads are metric or not, that would be a great help. Then I could source one somewhere else. Thanks!
wanted
200Tdi power steering pump banjo bolt size transientmechanic Defender Technical Discussions 1 January 7th, 2015 09:44 AM
2.5TD Lucas CAV banjo bolt grapplerdan Defender Technical Discussions 7 May 12th, 2014 02:41 PM
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 11:13 AM
Turbo oil feed banjo bolt size? o2batsea Defender Technical Discussions 1 July 22nd, 2013 04:55 PM
200tdi spill rail Banjo bolt torque tomaco1 Defender Technical Discussions 4 April 19th, 2012 03:29 PM
