Wanted - 95 RRC Rear Wiper Motor Assembly AMR3958 - Defender Source
Old October 7th, 2015, 10:12 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Looking for rear wiper motor, part #AMR3958. It seems to be a unique motor assembly to the '95 RRC SWB, as it does not have the round connectory, nor does it have a separate ground wire. The arm shaft also seems to be unique. This is what it looks like, with a broken outer sleeve and rotting arm...
Name:	95 RRC SWB Wiper motor.jpg
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old October 8th, 2015, 02:20 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
It's unique because the switch and most of the truck's wiring is adapted from the D1
Old October 8th, 2015, 10:22 AM
pl626's Avatar
pl626
Peter
You're right, it is a re-skinned D1. However, I think it may be build date related as well. My '95 RRC LWB, which was built in late '94, had the old style connections, i.e., round connector, separate ground wire. I had thought about hacking the wiring, but the arm was also slightly different, so I decided against swapping.
The fleabay motor I bought, I suspect was from a D1, as it had a mounting bracket as well and the arm was much shorter, but connectors were the same, and ground wire was integrated. I'm guessing you don't have any for the '95 RRC?
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old October 8th, 2015, 10:56 AM
Might be worth checking with Will Tillery
95, assembly, motor, wanted
91 RRC wiper motor.. o2batsea Defender Technical Discussions 4 January 9th, 2012 12:34 PM
d 90 sw rear wiper motor, bracket and arm lspindler5 For Sale - Parts 5 July 21st, 2010 04:49 PM
Wanted D90 or S3 Wiper assembly Turbofan Wanted 1 April 14th, 2010 03:59 PM
Rear door wiper motor assembly $100 evilfij For Sale - Parts 1 March 27th, 2009 03:37 PM
110 rear door wiper motor evilfij For Sale - Parts 0 March 2nd, 2007 04:00 PM
