Wanted - 94/95 NAS Temperature Gauge or VDO - Defender Source
Old May 21st, 2014, 11:53 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Looking for a 94/95 Temperature gauge before I go new...
Old May 22nd, 2014, 12:06 AM
Temp gauge you mean?
Old May 22nd, 2014, 12:21 AM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Yes. Thanks for the correction.
Old May 22nd, 2014, 09:20 AM
New VDO is probably cheaper that a second hand NAS
Old May 22nd, 2014, 09:28 AM
So here's what I went through recently, my factory temp gauge was acting up and intermittent. Thought it was a bad line maybe from the sender or ground - it wasn't. After monkeying around with it for a week I went ahead and ordered the VDO temp gauge & sender for about $50 total. Let me just say it is a HUGE improvement...gauge is much more accurate, and actually moves up & down according to actual temps (not to mention has NUMBERS on it!). You'll be happy with the VDO, and for the price can't go wrong. I ordered from egauges.com, here's the specs you need:
VDO 310-105 250F Water - 2 1/16" - Vision Black
VDO 323-417 Temperature Sender: 250F/120C - M16x1.5 - Screw - Single
Old May 22nd, 2014, 12:26 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Thanks. Makes sense to go this route. Was trying to keep the interior as stock as possible not I'm sure this will be healthier for the truck.
Old May 22nd, 2014, 12:30 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
as stock as the boost and auto are
Old May 22nd, 2014, 01:08 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Touche but those are still Land Rover Parts.
Old May 22nd, 2014, 01:14 PM
Actually my understanding is that the gauges used in the NAS are vdo gauges (if you look at the tach you'll see that too), but just were either done specifically for the NAS or they used the "cheapies" without the numbers/etc.
For as important as the temp is to monitoring things under the hood, I'd really urge you to replace it with the VDO (and you can keep the other gauges if you want...but I've started to replace those as well!).
Old May 22nd, 2014, 02:24 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
VDO it is. Thanks for the part number.
Old May 22nd, 2014, 03:14 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Is it just these two parts? Can I reuse the cable?
Old May 22nd, 2014, 03:23 PM
Yes, you can reuse the cable. The sender-side just plugs right in, on the gauge side you need to either: a) cut & crimp a new end to fit the VDO, or b) make a simple "jumper" wire (that I think is just a male spade terminal on one and, and female on the other).
Old May 22nd, 2014, 03:44 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Simple enough. Thanks.
Old May 22nd, 2014, 03:47 PM
Actually I just realized I was wrong on the sender-side...it's got a thumb-screw, so I actually cut & crimped a new electrical end with a eyelet. But other than that it's straight-forward. PM or post with any questions once you get it in-hand.
Old May 22nd, 2014, 03:50 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
If you already own a 94/95 gauge what wire would you use?
Old May 22nd, 2014, 03:59 PM
Gauge should plug right in.
Old May 22nd, 2014, 08:42 PM
Yeah but you need to remove the conditioner of death. I think that's where Ronnie's question originates.
Old May 22nd, 2014, 09:03 PM
Conditioner of death? Please expand . I didn't even have to pull my speedo cable, just popped off the dash cluster, undid all connections, plugged new one in (with a wire jumper I made up), good to go.
Old May 22nd, 2014, 09:27 PM
Ronnie has a 93 110 which has a box that always indicates normal temp even when the truck is doing a thermonuclear meltdown.
That needs to be extracted hence his wiring job is somewhat more complex.
Old May 22nd, 2014, 10:11 PM
Ronnie has a 93 110 which has a box that always indicates normal temp even when the truck is doing a thermonuclear meltdown. That needs to be extracted hence his wiring job is somewhat more complex.
Really easy though.
wanted, nas
Temperature gauge fogging up Caribsurf Defender Technical Discussions 4 July 10th, 2009 12:16 AM
FREE: Temperature Gauge madcowdungbeetle For Sale - Parts 8 January 29th, 2009 02:40 AM
VDO Temperature Sender chris snell Defender Technical Discussions 7 September 23rd, 2007 10:50 PM
Transmission temperature gauge ripp2002 Defender Technical Discussions 27 February 12th, 2005 08:42 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
