Wanted - 94/95 NAS Temperature Gauge or VDO - Page 2 - Defender Source
Old May 22nd, 2014, 10:21 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
FWIW, I replaced my 110 gauge per instructions with a second hand 94/95 that was supposed to be good. Removed conditioner, everytime the truck would start to warm up the gauge would peg itself in the red. Being paranoid, I kept shutting it off, bought a new sender just in case the one in there wasn't correct, still the same. No sign of overheating and no indication from a laser thermometer either. That was the final straw and I decided to just do it right and replace them all with New VDO. I haven't finished putting the truck together, but I anticipate a lot less headache, more information and better visibility...I'd suggest going this route.
However, if anyone is still looking for a 94/95 gauge, I believe I have two plus a stock NAS110, all of which I won't be using. I'd like to keep the 110 just to give the new buyer all the original parts I can, but the 94/95s are up for grabs for any offer. No guarantee they work, but I find it hard to believe that two failed the same way...I think I had another wiring problem causing my issue.
Old May 22nd, 2014, 10:25 PM
Originally Posted by evilfij View Post
Really easy though.
Agreed. I'd just tone the end of the sender with a multimeter, figure out which is the "other" end behind the dash (using the multimeter as well). You just need that wire, the 12v positive, and the ground. That's all the temp gauge needs to function.
wanted, nas
Temperature gauge fogging up Caribsurf Defender Technical Discussions 4 July 10th, 2009 12:16 AM
FREE: Temperature Gauge madcowdungbeetle For Sale - Parts 8 January 29th, 2009 02:40 AM
VDO Temperature Sender chris snell Defender Technical Discussions 7 September 23rd, 2007 10:50 PM
Transmission temperature gauge ripp2002 Defender Technical Discussions 27 February 12th, 2005 08:42 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
