Wanted: 200 TDI Engine - Defender Source
Old May 11th, 2017, 01:26 PM
slate997tt's Avatar
slate997tt
J. Martin
89 D90
Like the tittle says, the 2.5 TD engine on my D90 is tired and in need of a replacement or rebuilt, so I'm looking for a 200TDI instead. Please contact me if you have any good 200TDI engine.
Thank you
Jose
786-four93-88four4
Old May 11th, 2017, 01:49 PM
Contact Julian Knotting at https://www.facebook.com/Globallandr...?hc_ref=SEARCH He's also on this board
Old May 11th, 2017, 02:09 PM
bnoonan
Brice
1988 RHD 90
Zombie motors in GA is looking to move some things before moving again (if I understand the situation correctly). I saw they had a Craigslist post recently and talked to him the other day. He has engines for ya.
Old May 11th, 2017, 02:47 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Note there are Defender and Disco versions to be aware of. Both work but the Disco version sit differently in the engine bay as requires some creative plumbing work.
Old May 11th, 2017, 02:57 PM
slate997tt's Avatar
slate997tt
J. Martin
89 D90
Thank you, yeah I've been reading about the differences, also the need to relocate the turbo from a disco engine.
Old May 11th, 2017, 05:07 PM
Naplm00
Matthew
Not always, adapter pipes are avail
Old May 11th, 2017, 05:10 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I have a fresh Turner rebuild, still in the crate, fitted with a 'gas-flowed' cylinder head.
Also have the used ancillary parts: Disco turbo, fuel distributor, intake exhaust, alternator power steering, new radiator, intercooler, all the bits pulled from the 200 that failed.
Email is
Same place, new dogs.
Old May 11th, 2017, 05:38 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Rover Resource, Rover Resource
Richard Crouch, also here on the boards.
He sold me a very good Range Rover 200Tdi (same as Disco, or 12L).
You can fit a 12L into a LHD Defender by clocking the turbo and getting a TD5 steering shaft.
Old May 11th, 2017, 08:52 PM
rtcgb's Avatar
rtcgb
Richard Crouch
61 11a 'Lloyd', 87 130 'Big D',
200 def tdi
I have some used 200 def engines that I will refresh (bearings, rings,valves etc)
if thats of interest
message or call
860 480 0091 Richard
Old May 12th, 2017, 06:28 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I would do some serious Google background checking on Zombie Motors before engaging in any business with them. Lengthy threads here about him as well as Pelican Parts.
Old May 12th, 2017, 07:26 AM
only an isssue on a lhd truck and you can clock the turbo slightly and use a td5 steering shaft. No other issues.
We have two defender 200 tdi's for sale here with lt77s gearbox included
Old May 12th, 2017, 08:42 AM
BlackField's Avatar
BlackField
Oscar
D110
I have a 200tdi running in my 110 right now. I need to pull it to swap in my 2.8. comes with LT77 and an LT 230 if you want it.
I'm in NYC I could deliver at cost in early July
Old May 12th, 2017, 08:54 AM
1of40's Avatar
1of40
1of40
These things are no different than the rest of life, in that they are only as strong as your weakest component. Be sure you do your due diligence on the condition of turbo, intercooler, radiator, injection pump, tuning and gearing choices behind the engine.
The good/bad thing is there are lots of combos to work with. The good thing is you have lots of experience here in the wings ready and willing to help share their knowledge too. Even something as simple as choice of motor/t-case mounts can make a difference in the project ultimately meeting your expectations.
Old May 12th, 2017, 11:09 AM
slate997tt's Avatar
slate997tt
J. Martin
89 D90
Thanks for all the info guys... Still looking I already spoke with Uncle Douglas and he is sourcing me an engine. Will keep you guys informed.
Old May 15th, 2017, 05:31 AM
slate997tt's Avatar
slate997tt
J. Martin
89 D90
Still looking guys... waiting for a couple of replies but haven't been able to source anything yet.
Thank you
Old May 15th, 2017, 07:51 AM
110fender
devin
1987 110
I have two available. Sent you a PM. Thanks.
Old May 15th, 2017, 08:06 PM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
I can offer 200tdi defender engines for the following direct take out 1800 plus shipping, Refreshed(new timing belt engine fully checked(head off and sump off, any worn parts replaced), recon injector pump, recon turbo, recon injectors new glow plugs, all outer ancillaries second hand but checked 4000 plus shipping, or fully re-manufactured units for 6750.00 plus shipping.
References can be provided.
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old May 15th, 2017, 08:13 PM
1of40's Avatar
1of40
1of40
Highly recommend getting it all done right in the beginning. You'll eventually need to either way.
engine, tdi, wanted
International HS2.8L Michael Defender Technical Discussions 448 April 21st, 2017 03:58 PM
3.5 V8 vs 200 Tdi bbdesoleil Defender Technical Discussions 15 August 29th, 2010 09:17 AM
thinking of buying 200 tdi Defender discotdi Defender Technical Discussions 3 August 27th, 2010 12:25 PM
WANTED: 300 tdi radiator, new or used. In a bind! dmarchand Wanted 0 June 30th, 2005 03:35 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 12:45 PM
