Wanted: 2.5td Fuel Injector Pump - Defender Source
Old May 10th, 2017, 09:07 AM
DrZ123
Zach
Need a rebuilt injector pump for a 2.5 turbo diesel engine! Anyone have one for a reasonable price?
Thx
Old May 10th, 2017, 09:46 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you have a bad IP, I would seriously consider replacing the lethargic 2.5TD with a more powerful engine.
If you're dead set against an engine swap, good luck with your search.
RDavisinVA
Old May 10th, 2017, 09:57 AM
https://www.johncraddockltd.co.uk/la...-old-unit.html
REBUILT INJECTION PUMP 2.5L TURBO DSL, ETC7136E, RNQ665 - Rovers North - Classic Land Rover Parts
Old May 10th, 2017, 10:15 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Not mine!
Defender 200tdi engine $550 and other parts
https://savannah.craigslist.org/pts/6122289870.html
~ Semper Fidelis ~
Old May 10th, 2017, 10:37 AM
DrZ123
Zach
I know they say they have them, but they DO NOT, I called.
Old May 10th, 2017, 11:53 AM
DrZ123
Zach
I am going to be using this truck for a bit, and then may keep it or may sell it. 1989 110.
Wondering if the $10k it will cost all in for a 300tdi will return in value.
Old May 10th, 2017, 01:55 PM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Thx
The cheapest price I have found for an IP (+/-$600 USD w/ core...+/-$800 w/o core) is on ebay UK.http://redirect.viglink.com/?format=...6%20%7C%20eBay Yes, they are a bit pricey but still ALOT less than a 200/300 swap. I could not find any new or rebuilt stateside. Luckily I had purchased a used 2.TD motor w/ a donor IP still attached...took a chance that it was good and it runs like a charm.
These pumps are pretty tough...the only reason for replacing mine was self inflicted...I broke the IP housing while changing the boost diaphragm are you sure yours is pooched? What are symptoms?
fuel, wanted
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 09:46 PM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
