Wanted 2.5 fuel filter pipes - Defender Source
Old April 25th, 2017, 11:51 AM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Tying to piece together a 2.5 n/a that was missing the fuel pipe between the lift pump and the fuel filter and also the spill rail return line that goes from spill rail to fuel filter banjo. If you have spares your willing to part with it would be greatly appreciated.
Old April 25th, 2017, 12:10 PM
The Dro
Dro
1988 Ninety
Buy new... They are cheap.
ETC6903 Lift pump to filter
ERC4480 Spill rail
Old April 25th, 2017, 04:15 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
You should re-plumb your setup to a spin-on fuel filter that DOES NOT route the return line back into the fuel filter.
RDavisinVA
Old April 25th, 2017, 05:09 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
I'm just trying to help a friend out and get it out asap on the cheap. I am curious why the return would be routed back through the filter in the first place?
Turned out to be:
ETC6903 filter to lift pump-cheap
NRC8916 spill rail to filter-not in stock or cheap
Thanks for responses
Old April 25th, 2017, 06:09 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
So the trapped air keeps recirculating and is almost impossible to purge.
RDavisinVA
Old April 25th, 2017, 07:17 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Excellent
Old April 27th, 2017, 08:18 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Turned out to be:
Hey Matt, I eliminated the loop back to the filter, basically just took the tank return line at the top of the filter off the banjo fitting then removed the short section of tubing between the spill rail and filter banjo fitting and then connected the tank return line directly to the end of the spill rail. The bolt and copper washers at the top of the filter can be reused as a plug/bleed screw but you will need to improvise a spacer to replace the banjo fitting. In my case I had an extra single port banjo fitting left over from a fuel line...I just capped the port with a short piece of tubing & plug and installed. This is now just a bleed port at the high point of the system.
I see you are in Maine...where are you located?
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
Air Filter Bracket Parts/Ideas/Pix wanted JimC Defender Technical Discussions 7 April 4th, 2010 12:09 AM
Inline fuel filter with diesel? JimC Defender Technical Discussions 36 August 29th, 2009 11:15 AM
Help wanted: Difference between RR 2.5 TD and 2.5 DSE lakis Defender Technical Discussions 0 November 17th, 2004 10:23 AM
