Wanted 127/130 gas fuel tank... - Defender Source
Old September 4th, 2016, 06:59 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Need a fuel tank that will work in the 127/130 with high pressure 4.0 fuel pump. My current tank is metal with 2 mounting bolts close together holding it up in the front and 2 bolts further apart in the back. Presumably it's the original 3.5 tank that was retrofitted for the 200tdi we pulled out of the truck. Maybe mine can be retro fitted. Thanks! Click image for larger version
Old September 4th, 2016, 08:37 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Do you not want to run an inline Walbro or Bosch 044?
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old September 5th, 2016, 12:56 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
There's an idea!
Old September 6th, 2016, 01:48 AM
Why not use a metal tank RRC/NAS 110 fuel pump with that tank?
I thought the D90 pumps were all the same 94-97 so I don't see why it would not work. IE I don't think there is a difference between GEMs and 14CUX in fuel pump pressure.
127 Rapier :: 1990 Land Rover 127 HAWKER748 Defender & Series Truck Registry 0 July 18th, 2016 07:18 AM
Defender 127 V8 Rapier LHD :: 1990 Land Rover Defender 127 Rockymountainrover Defender & Series Truck Registry 1 February 22nd, 2016 01:05 AM
Wanted 1990 or older Defender 127/130 Double Cab RX6RCROL Wanted 1 February 22nd, 2015 10:48 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
127/130 Double Cab HCPU Uncle Douglas The Flea Market 11 December 17th, 2009 12:48 AM
