Wanted 10 spline TruTrac - Defender Source
Old September 13th, 2016, 12:46 PM
cdb
Clark Bowen
in good condition.
2011 RR HSE -
2001 GMC 2500 4wd
Old September 13th, 2016, 01:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This post is jogging my memory...
I have 5 or 6 Range Rover Classic 10 spline 3rd members and I think 1 of them has a Tru Trac in it.... I'll try and check in the next day or so.
Rent my
Old September 13th, 2016, 08:30 PM
cdb
Clark Bowen
Thanks Jeff
2011 RR HSE -
2001 GMC 2500 4wd
Old September 14th, 2016, 01:07 AM
badvibes's Avatar
badvibes
Jeff
1991 RRC
You probably already know but Trutracs are set up for either front of rear applications. You can use a rear for a front, or vice versa, but you may need to switch the internal gears/parts around. Just did this to my Classics front axle. Here's a link to the instructions.
https://discoweb.org/truetracgears/
Old September 14th, 2016, 05:25 AM
cdb
Clark Bowen
No I didn't and I'm glad you brought it up.
2011 RR HSE -
2001 GMC 2500 4wd
Old September 25th, 2016, 11:31 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
i'll try to post a pic
Rent my
Old September 25th, 2016, 11:37 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I can never get more than 1 picture to post from my phone
Rent my
Old September 25th, 2016, 11:42 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
See if this works
Rent my
Old September 25th, 2016, 11:50 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Let me state: I never ran this diff in one of my own trucks so I dont know if it was a FRONT or a REAR diff??
It seems pretty *tight*, that is not too sloppy if that makes sense.
I am not a diff expert and do not set them up.
I can pull them and replace them.
Rent my
Old September 25th, 2016, 11:51 AM
cdb
Clark Bowen
Jeff....
Are those 3.54 gears?
2011 RR HSE -
2001 GMC 2500 4wd
Old September 25th, 2016, 11:55 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Is it compatible with a 1985 110 front end?
You little rebel, I like you.
Old September 25th, 2016, 12:14 PM
cdb
Clark Bowen
A previous post told how to determine whether it is front or rear and how to switch the gears on the TruTrac for front or rear application so we are fine there.
If it is a 3.54 diff would you pull the TruTrac from the diff to save weight and because it is going in a Series LR with 4.70 gears?
The 3.54 would be a bit too high I have discovered
2011 RR HSE -
2001 GMC 2500 4wd
Old September 26th, 2016, 06:12 PM
cdb
Clark Bowen
They are 3.54 gears and I'll wait for a separate TruTrac unit rather than the entire diff so if you want them I'd suggest PMing Nomar directly
2011 RR HSE -
2001 GMC 2500 4wd
ac, wanted
WTB: 4.7 24-spline (4-pin) complete rear diff 3rd member (24-spline axles too) modrover Wanted 1 November 18th, 2015 08:40 AM
WTB: 4.7 Rover 24-spline diff with locker & 24-spline axles modrover Wanted 4 September 27th, 2015 06:24 PM
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 04:20 PM
36 spline versus 48 spline steering wheels transientmechanic Defender Technical Discussions 31 November 13th, 2013 08:57 PM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 04:29 PM
