Turn signal/horn switch - Defender Source
Old June 22nd, 2011, 08:11 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Wondering if anyone has a working blinker/horn switch. My blinkers are going in and out, mostly out these days.
Old June 22nd, 2011, 02:37 PM
CDeWan
Clay DeWan
5.3L beastie
relay problems?
Old June 22nd, 2011, 02:46 PM
Had a similar problem on my '85 truck. Disassembled the turn signal switch and turns out it was working just fine. Problem was somewhere in the hazard switch or wiring.
Really not much to go wrong in the turn signal switch as it is very simple - just three contacts and a brass cylinder contactor.
Old June 22nd, 2011, 03:23 PM
CDeWan
Clay DeWan
5.3L beastie
problem
Have a similar problem if my hazard switch is not fully disengaged no blinky!
Old June 22nd, 2011, 03:47 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Hmm. It started one day when I left the vents open during a rain storm and they didn't work till the next day. I took the steering console apart yesterday and unplugged the wires and plugged everything back in and still nothing. I did notice that one wire got up to 133 degrees when the headlights were on. Yikes!
It certainly seems simple enough so that's why I just figured it was the switch.
Old June 22nd, 2011, 04:20 PM
The turn signal stalk has three wires for the turn signal. They are there to connect the blinker bulbs to the flasher relay through the hazard switch (one wire to the hazard switch, the other two for the left and right indicators). There's nothing inside the turn signal stalk that could short out - the three contacts are physically separated from each other by thick plastic walls.
Still would check the wiring and the hazard switch first.
Old June 26th, 2011, 10:07 AM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
I have new switches but I would suggest the flasher (likely water ingress). I bet theres water in the flasher.
Old June 27th, 2011, 12:11 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Well what exactly is the flasher then? Is that the hazard relay?
I checked the connection behind the hazard switch and pulled apart a few times but still no go.
------ Follow up post added June 27th, 2011 12:17 AM ------
FWIW my switch makes the quick blinker noise like a bulb is out, so ultimately I think the switch must be ok, right? If not I'll buy one from you Stephen.
And BTW, you guys are great. I post something in the wanted section and I get replies about how to fix the thing!
Old June 27th, 2011, 11:48 AM
The EP26-style flasher relay is designed to flash a bulb on the hazard switch itself, as well as the blinker bulbs.
What the turn signal stalk does is connect either the left or right blinkers to the EP26 flasher relay output.
The hazard switch connects both sets of blinkers to the EP26.
If the flasher relay is blinking quickly as if there is a bulb out, it is sensing a change in impedance in the connection to the blinker bulbs.
There are three wires coming out of the base of the turn signal switch. Do not disassemble the turn signal switch at this point. Use a multitester and test for continuity between the three wires with the turn signal in the neutral, left and right positions and the output pin of the flasher.
I'm going to have to put up a wiring diagram if I can make one.
Old July 10th, 2011, 04:10 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I'm refreshing this because after a week of flashers working, now they are not working again.
I opened the fuse panel and found the little clicker box that makes the blinker noise in the cabin. It definitely had bad connectors due to water ingress. I took it off and cleaned up the male pins and when I connected it to the turn signal pigtail I could get it to work properly a couple of times by tapping on it but then it would go to the rapid clicking again. This must be the culprit.
Is this the flasher relay mentioned above?
I searched for the above mentioned number and couldn't find a source for that part. I did a search for the number on my part, picture attached, and couldn't find a source for that either.
Any help in solving this silly issue would be appreciated.
Jeff
ID:	40185   Click image for larger version
Old July 10th, 2011, 05:15 PM
You can use any generic 4-pin EP26 flasher. Available at any Autozone, Pep Boys, Oreillys, etc.
The reason you need an EP26 is because the EP26 is designed to flash a light on the hazard switch itself.
If you plan to switch to LEDs make sure you get an "electronic LED flasher" version of the EP26.
Old July 10th, 2011, 05:23 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Thats the water damage I suspected. I have the OEM flasher but if it were me I would head to autozone.
Old July 10th, 2011, 08:16 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok great. Thanks guys.
horn, signal, switch
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
