Trutrac rear 3rd member - Defender Source
Old November 20th, 2013, 12:12 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Looking for a drop in rear third member with trutrac and stock 3.54 gearing. For disco/defender 24 spline. Could go for an ARB instead, but definitely not a detroit. Preferably with low miles. Seeing if anything is out there before I just buy a new Trutrac. Thanks
Old November 20th, 2013, 08:07 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
PM sent Mack
Old November 20th, 2013, 08:12 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
What's wrong with a Detroit?
Old November 20th, 2013, 08:19 AM
1of40's Avatar
1of40
1of40
Nothing that I've found. I've had one in my daily driver going on nine years, 80,000 miles. I can give you a list of the guys I've wheeled with over the years. They'll attest it has never failed me.
Clay
Old November 20th, 2013, 08:34 AM
rovertrader's Avatar
rovertrader
Dale
Locker of choice- mechanical, and always on the ready! Holds up ok under the 600hp K-30 ;-)
Old November 20th, 2013, 08:36 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by 1of40 View Post
Nothing that I've found. I've had one in my daily driver going on nine years, 80,000 miles. I can give you a list of the guys I've wheeled with over the years. They'll attest it has never failed me. Clay
I wanted to hear his reason? I have run one in multiple vehicles with no fault ever! Blew a ring once but the locker was still good. Put in and forget about it! Best there is in my opinion, simple and you don't have to worry about compressors, lines or other issues. I wouldn't put up front but that's a different story. I do have a Detroit in a third set up that I'm selling! but you don't want a Detroit.
Old November 20th, 2013, 01:27 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I don't have anything against a Detroit and they work great off road. I had one in the rear of a vehicle I drove in the snow/ice quite a bit and it would engage inconsistenly and I would be correcting oversteer quite a bit. Maybe it wasn't working properly. Anyone else ever have that issue?
Old November 20th, 2013, 01:29 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That is why I went with a selectable locker. A friend of mine had a truck with a detroit in the rear and TT in front, snow driving was very sketchy in corners.
ac
1987 LHD 90 2.5td broadstone For Sale - Vehicles 4 May 21st, 2013 07:27 PM
Wanted: Rear Reflector for Cross Member 95/97 D90 JQ11 Wanted 0 January 14th, 2013 11:40 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear 3rd Mem 4.75 R&P w/ Detroit orlandog For Sale - Parts 0 April 18th, 2004 01:05 AM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
