TPS Sensor - Defender Source
Old May 28th, 2013, 09:47 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
TPS Sensor
Anyone have a flat prong TPS for a 95? Possibly used?
I got a round plug and spliced the wires over the weekend, but its running rich and stumbling at idle.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 28th, 2013, 10:50 AM
how do you know that's the problem?
I'm not sure how the TPS would cause those type of issues.
Old May 28th, 2013, 10:58 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Sounds more like an idle air control valve symptom so worth checking that, too.
Old May 28th, 2013, 10:59 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
I was throwing a code with the old one. Engine would feel like it was cutting off when driving for a split second. I replaced the TPS with one off a Range Rover that Brian K (Brewie212) dropped by. Spliced the wires, cleared the code and the symptoms while driving went away. The old TPS (flat plug) and the newer one (Round plug) have different gauge wires so I dont know if it is a resistance issue or if I just need the correct part.
It idled fine with the old TPS, just didn't drive very well when accelerating.
This part is reasonably new. I cleaned it to be safe.
1995 Defender ST
1996 Discovery SE7
Old May 28th, 2013, 12:00 PM
resistance change would be constant ... and the gauge of wire will make no difference.
Have you measure the resistance on the bench and see if you have a clean sweep? its easier with a meter with a dial indicator rather than lcd display.
http://p38arover.com/rover/p38a/Engi...UX_Systems.pdf
see page 73 to measure voltage when on the vehicle
http://www.g33.co.uk/images/PDFS/LR_...ionSystems.pdf
Old May 28th, 2013, 09:51 PM
Roving Beetle
Doug
I have an entire intake, throttle body, sensors, iac valve and all. Cheap.
Ill box it and mail it off if that helps. Shipping costs and some beer money and its yours. Or I can rob the sensors and mail just those.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old May 29th, 2013, 08:50 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I am sure I have exactly what you are looking for, but the round plug TPS from a 95 RRC sure aint it.
Old May 29th, 2013, 09:27 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
That is why im in search of the flat/square plug. I figured it couldnt hurt to try the wire them together. Going against kindergarten teachings of fitting square in round hole.
It kinda works. Isn't throwing the code anymore. Just doesn't run all that great either.
1995 Defender ST
1996 Discovery SE7
Old May 29th, 2013, 09:46 AM
crown14's Avatar
crown14
Verticalscrote
Drop it off, Ill get it running right.
sensor
Need TPS Throttle Position Sensor for a 95 LWB flat prong evilfij Wanted 0 August 10th, 2012 12:11 PM
Throttle Position Sensor (TPS) over voltage leastonce Defender Technical Discussions 6 May 17th, 2012 08:48 AM
Throttle Position Sensor (TPS) Duke D90 Wanted 0 April 3rd, 2010 05:15 PM
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
