tire carrier - Defender Source
Old April 23rd, 2009, 07:15 AM
ctrover
jim larson
1984 v8 127
tire carrier
looking for an original tire carrier that bolts through the rear door like on the older 110's and series.
jim
Old April 23rd, 2009, 10:12 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I've got one that came off my NAS 110 if you want. I think it is what you are looking for. I have all the pieces including the door stiffeners in good shape. Make me an offer.
Old April 23rd, 2009, 01:50 PM
bjf's Avatar
bjf
barry f
94 ST #395
Andrew what are you using on your 110?
Old April 23rd, 2009, 02:15 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Hey Probably has the Mantec swing on the rear... I know I do, and it makes a huge difference in the performance of the rear door.
D
Old April 23rd, 2009, 02:47 PM
dbj2003
Brandon Jones
94 Defender 90 POE
I have a used Mantec rear tire carrier (for a D90/110) in vg condition available for $300 shipped. Save yourself the new door in a few years.
Old April 23rd, 2009, 03:38 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I have a bearmach swing-away from Craddock I am using. I am very happy with it, and with the current exchange rate, it was dirt cheap.
Old April 23rd, 2009, 03:47 PM
I bought a Mantec which will be going on my truck. The door just does not survive with the tire hanging off of it.
Old April 23rd, 2009, 07:49 PM
ctrover
jim larson
1984 v8 127
Thanks andrew!
Old April 23rd, 2009, 08:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
If you have a mantec I know it isn't mounted to the door but it looks like there is some brace that hits the center of the door. Does the door still get some load because of this brace? I am about to have my door fixed as it cracked inside and I wanted to know if I just left it alone and went mantec would it still creak like it does now?
Old April 23rd, 2009, 11:16 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It doesn't really get much load per se, but it will still stress the area some. That little dog bone piece should mostly just keep the wheel from swinging freely and ensures that it moves with the door when it is opened. I imagine there is some load once the tire is on there, but nowhere near the load of a full tire, not to mention the stress on the door when you swing it closed with all that weight hanging on it.
Old April 24th, 2009, 12:39 PM
dbj2003
Brandon Jones
94 Defender 90 POE
pic to follow this weekend when I get home
Old April 28th, 2009, 12:06 PM
dbj2003
Brandon Jones
94 Defender 90 POE
Mantec carrier pics
Pics attached, original PM response order was as follows, so bjf has first dibs. Thanks for the interest and patience.
-Brandon
bjf
Chaucer
MC22958
ID:	19090   Click image for larger version
Old April 28th, 2009, 12:20 PM
Chaucer
Will
93 110 | 97 90
Cool - what's with the back mounting plate? Last Mantec I had (on the old 90) didn't have that square tubing in the back, just a flat plate between the door and the plunger-like thingy. Is that how they come nowadays, or is that custom for your rig?
Old April 28th, 2009, 02:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Odds are it will be mine. Isn't there some part that attaches to the rear door?
Old April 28th, 2009, 02:50 PM
I'll take it if they don't.
Ron
Old April 28th, 2009, 02:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ron
Do you know from looking at those pics what attaches to the door?
Old April 28th, 2009, 03:36 PM
Chaucer
Will
93 110 | 97 90
In the second pic, you can see 4 holes; one in each square tube piece. It appears that is what Brandon was using to attach directly to the door.
I have installed the Mantec carrier before on my old 90 SW. When you remove the stock carrier, you cover it's three holes with a flat sheet of metal that bolts onto the outside of the door. Then on top of that, you bolt the plunger thingy/articulating arm/piston (sorry don't know the proper term) which in turn bolts to the carrier frame.
What I was wondering [sorry for the hijack] was whether or not the new Mantec carriers come this way now with the square tube pieces, or if this is a custom spacer Brandon was using.
Old April 28th, 2009, 03:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
does the flat sheet come with it?
Old April 28th, 2009, 03:42 PM
Chaucer
Will
93 110 | 97 90
It did with mine. Check this site...really great installation pics. See the fourth pic down:
http://www.rebaseonu.net/go/story/id..._installation/
At the bottom of the page, you can download the pdf of the instructions...
Old April 28th, 2009, 03:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
looks simply. Not sure I understand the thing that mounts to the door. Does the carrier swing into it? IS it a shock?
carrier, tire, tire carrier
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
