TDI style forward crossbar needed - Defender Source
Old November 9th, 2015, 04:58 PM
Need to swap out my V8 style, as it interferes with the diesel exhaust routing.
Anybody have a used one in their parts bin before I order new? I need the squared off style crossbard, versus the angles one I have now.
I need this style: KVB500060
I have this style:
Mark Kellgren
KM4BOR
Old November 9th, 2015, 05:05 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Plain steel or galv…
Both in stock if nobody else has them avail.
Old November 17th, 2015, 08:53 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I have a brand new galvy one. Trade you straight up for your V8 one if you still are looking
Old November 17th, 2015, 09:01 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Mark, I have a couple if you haven't gotten this taken care of.
Old November 18th, 2015, 12:28 PM
Going to trade w oneten. Will reach out if it doesnt work out. Thanks buddy
Mark Kellgren
KM4BOR
Old November 27th, 2015, 08:10 PM
Thanks to Sam for trading me crossmembers. The swap was easy-breasy with all the bolt holes lining up perfectly. I've attached the picture comparing the two for posterity, where you can see the restricted areas on the V8 style at the edges. My TDI exhaust only had about 1/2" clearance between the tcase and the crossmember, which caused a nasty rattle at idle or under load. I recommend this item as a swap for anyone going from V8 to TDI.
Mark Kellgren
KM4BOR
tdi
Trade: NAS ST Grey Leather Forward Facing Bench for Grey Vinyl Forward Facing Bench KKilo23 For Sale - Parts 4 October 15th, 2013 12:24 PM
SD Rack Front Crossbar the_eaze Wanted 8 September 20th, 2010 03:14 PM
Soft Top Crossbar mmac Wanted 5 June 28th, 2010 01:14 PM
SD Rack front crossbar the_eaze Wanted 4 November 27th, 2009 01:57 PM
Crossbar Clamps bjp Defender Technical Discussions 7 November 21st, 2008 04:16 PM
