Tailgate bar clips needed - Defender Source
Old June 14th, 2012, 12:34 PM
pdella
Paul
1997, Defender Alpine White
Converted my '97 with Fiberglass top to ST, bought a tailgate bar but didn't get the clips to install the tailgate bar to the rear. I need the 2 clips that the tailgate bar slides into.
Old June 14th, 2012, 12:49 PM
so i guess you didn't buy the one I recommended in your other thread afterall?
http://www.defendersource.com/forum/...ad.php?t=37565
Old June 14th, 2012, 12:58 PM
pdella
Paul
Correct..
that is correct- got the bar saved some $$ but found out that the car didn't have the clips... you were right!
Old June 14th, 2012, 01:06 PM
The good news is that it's Summer and I'm assuming the top will not be on permanently during the sunny months. The other good thing is that (at least on my top) the clips are not completely necessary, but it does help to secure it a little I guess.
When you put your top on, at the back you'll secure the left and right sides (behind the tire carrier) of your top to the belt rail and then sleeve this tailgate bar into your rear window, and then put the tailgate bar on the interior side of your truck and zip the window closed. Your left and right sides of your top will hold the tailgate bar on the inside of your truck, and the weight of the tailgate bar will keep it from flopping around much.
Old June 15th, 2012, 04:16 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Do you have any illustrations of the part you need I am pretty sure I have a set of them...
Old June 15th, 2012, 04:29 PM
pdella
Paul
Its the small clips illustrated here:
Name:	tailgate bar clips.jpg
clips, tailgate
D-90 ST Clips for the Tailgate bar Hinckley423 Wanted 0 November 28th, 2011 07:29 PM
Tailgate clips and bar needed. toona Wanted 6 May 5th, 2009 09:41 PM
needed: roll bar parts, tailgate, soft top bstraw Wanted 3 March 21st, 2006 10:01 AM
Header bar, yellow hinges, tailgate bar clips mspell Wanted 1 October 4th, 2004 04:20 PM
Have a trashed Bestop soft top? Need tailgate clips, vertical rails, misc. jaherring Wanted 3 September 24th, 2004 09:15 PM
