SW internal roll bar - Defender Source
Old December 12th, 2007, 03:32 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
looking for the B pillar roll bar for a D90
Old December 12th, 2007, 03:38 PM
Thats how it goes with these "POE conversions" - before long you find yourself wanting all the right parts. I'm still eyeing a SW rear door!
Oh yeah, and interior rear window trims...
Old December 12th, 2007, 03:43 PM
Gkase's Avatar
Gkase
George Kase
doesn't hurt to ask before I drill holes in the top...I still wouldn't convert to the full rear SW door though. Having owned both styles of truck it strikes me that the POE setup makes hauling lumber or anything that needs to stick out of the truck much easier...
Old December 12th, 2007, 03:54 PM
There is a lot of adjustment in the placement of the roll hoop, so as long as your holes are in the rearward flange on the rib that runs across the top from side to side, you should be able to fit it at any time. The cage doesnt bolt directly to the internal hoop, instead there are two intermediate pieces.
I'm still not satisfied with the seal at the lift gate, thats the only reason that I'm whining. No way am I going to spring for a door + paint when I've got a 110 that needs a lot more paint.
Old December 12th, 2007, 04:00 PM
Gkase's Avatar
Gkase
George Kase
Yeah, I'm not happy with that either...wish I could get a shot or two of what the stock POE rear hatch seal set up is like...I did finally mount a strut support for the hatch that works pretty decent though...
Old December 19th, 2007, 02:01 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
Lift gate - tail gate seal
I went with a very simple solution that I have been very happy with for 4 years now. I bought a simple neopream like garage door seal from Orchard Supply hardware. It is the type that is used for door to floor contact. It's design has a built in shape that provides a constant backpresure to keep out the environment (cold temps, wind, water ,dusts etc) The chemical compound of this door gasket is engineered to be UV resistant. I used a simple anodized aluminum bar to hold it inplace. I have attached some pics for you to see how it works.
Jim I took these pic over at the Alviso marina (before you lived over there)....
ID:	11412   Click image for larger version
ID:	11414   Click image for larger version
Old December 19th, 2007, 10:55 AM
Gkase's Avatar
Gkase
George Kase
Len...
that looks very buttoned up...congrats. I put my aluminum strip on the inside which is creating the difficulties...
I'm going to post a request to see if any actual POE guys can post pix of the factory method...
thanks again for your help.
George
Old December 19th, 2007, 01:44 PM
The original seal is a rivited on piece of aluminium to the steel portion of the liftgate with a normal rubber seal attached. Series style with the galvanized piece is much better.
Ron
Old December 19th, 2007, 01:52 PM
Series style is great, but its designed so that you close the lift gate after the tailgate, which doesnt work so much with the NAS tire carrier and brake light bar in the way.
roll bar
New SW roll bar installation tomaco1 Defender Technical Discussions 11 July 1st, 2008 08:36 AM
D-90 Roll Bar Pads roverboy For Sale - Parts 2 November 16th, 2005 10:28 AM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
Rear roll bar pendy Wanted 0 June 17th, 2004 01:10 AM
Roll bar pads for SW Chaucer Wanted 3 December 3rd, 2003 02:44 AM
