Steering column new or used - Defender Source
Old September 17th, 2008, 01:34 PM
CDeWan
Clay DeWan
5.3L beastie
Guys,
Need a steering column from steering wheel to firewall, just the column and sleeve for a 94 D-90. (note to self - don't beat on the column when trying to remove steering wheel bad idea). Preferable used cause I am cheap but in good condition. New I am getting a qoute of about $190 from RoversNorth. o....how hard are they to replace? I am think removal of steering surrond and turn singal cluster after pulling off wheel and sliding through firewall or...?
Thank you,
Clay
Old September 17th, 2008, 01:53 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
You can change the inner shaft of the column without taking all that stuff apart. You'll just need to find a new column inner shaft.
I have some, but they are UK spec and have a different spline count for the steering wheel (an NAS wheel will not fit).
Email:
Old September 17th, 2008, 03:46 PM
CDeWan
Clay DeWan
5.3L beastie
Fidel,
I put a TD5 leather wheel on the 94 and it seemed to work. But not sure of the difference. I should probably count the splins.
I shouls also mention that I bought the wheel out of Germany so maybe that is the difference. Do you have a rubberized A bar?
Steering column refurbishment Muscat Defender Technical Discussions 0 February 19th, 2008 02:07 PM
Steering adaptor for Euro spec column? KevinNY Defender Technical Discussions 4 November 27th, 2006 05:05 PM
steering column u-joint Noah Defender Technical Discussions 0 September 8th, 2004 07:04 PM
How to remove steering column? Chris Cox Defender Technical Discussions 6 October 22nd, 2003 07:24 PM
