Steering Box - 4 Bolt LHD (1989) - Wanted - Defender Source
Old January 25th, 2016, 11:11 AM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Red face Steering Box - 4 Bolt LHD (1989) - Wanted
Looking for a steering box for a left hand drive 1989 Defender 110. New or used, located in NY area but shipping is ok.
Thank you
Jeff
Old January 25th, 2016, 11:13 AM
Disco 1 steering boxes are the same. Most junk yards.
Old January 25th, 2016, 11:17 AM
phoenix37's Avatar
phoenix37
john
are RRC boxes also the same?
Old January 25th, 2016, 11:56 AM
Discos use a more traditional arm with a tapered hole.
And I would suggest changing to the Disco arm while you are at it. It makes TRE replacement easier. You just need a clamp for the steering dampener.
Old January 25th, 2016, 11:59 AM
yep-better design
Old January 25th, 2016, 12:08 PM
I agree as well, but then he is looking at redoing the stabilizer, and getting the arm of can be a real pain. Just so he knows what he is in for.
-Jeff
But he is getting a "new" box... If he gets one from a Disco, the arm is on it.... Take the tie rod at the same time. Buy a damper relocation kit (lots of options) and there you go.
Old January 25th, 2016, 12:16 PM
FWIW many here seem to be of the impression that the difference between a three bolt and four bolt box is how they attach to the frame. The difference is @ the top/cap plate on the box where the adjuster is, not how it attaches to the chassis.
I have both three bolt and four bolt boxes here and there is virtually no performance difference between them and they are interchangeable as long as you change the pitman arm with the box as the lower splines are different. One is simply an older design than the other.
Many consider the three bolt to be stronger internally.
http://www.rangerovers.net/forum/8-r...-3-4-bolt.html
Old January 25th, 2016, 06:57 PM
WestCoastRover
Jeff
2000 TD5
Thanks! I wasn't aware of this swap. Something worth considering. Though I don't really want to go changing the other components as I have some upgraded steering parts.
The leak is coming from where the shaft coming from the steering wheel enters the box.
Is there a seal kit? (I have the kit already for the pitman arm side) Or is it time to change the box?
-- Anyone have a rebuilt, used etc 4 bolt for the LHD 1989 110?
-- Does the box from 94-97 NAs fit?
Old January 27th, 2016, 08:49 PM
WestCoastRover
Jeff
2000 TD5
eBay is being a little difficult. Disco 1 is 1990-1994 right? eBay seems to think it's 94-99.
Still having trouble tracking something down.
Old January 27th, 2016, 08:51 PM
Originally Posted by westcoastrover View Post
ebay is being a little difficult. Disco 1 is 1990-1994 right? Ebay seems to think it's 94-99.
94-99
Old January 27th, 2016, 09:08 PM
WestCoastRover
Jeff
2000 TD5
94-99 is Disco 1, great! a lot more options. So if I buy the box fro a Disco 1, It will bolt in? And I just have to pull the pitman arm off, and replace it with my 1989 Defender 110 Pitman arm?
Old January 27th, 2016, 09:21 PM
Yes. Getting the pitman arm off is usually an absolute beeotch. If its still driveable what many do is loosten the nut about an 1/8 inch and drive the truck a bit to get the tapered shaft/pitman forced fit to loosen. Same trick works well for rear axle ball joint.
Range Rover Classic 87-95 is also same box.
Old January 28th, 2016, 08:14 AM
WestCoastRover
Jeff
2000 TD5
Great trick.
Ok before I order, can someone confirm if they think this is the correct one? There's a part number listed QAF500040 Thanks
1994 1999 Land Rover Discovery I Steering Gear Box QAF500040 1 Year Warranty | eBay
Old January 28th, 2016, 10:07 PM
WestCoastRover
Jeff
2000 TD5
Any input on that link? Would love to get this ordered
lhd, wanted
adwest ntc8223 manual steering box bolt size cgalpin Defender Technical Discussions 4 June 15th, 2015 10:10 PM
WTB RHD 4 bolt Steering Box icnsltmfg Wanted 1 May 27th, 2015 11:44 AM
4 Bolt Steering Box Input Shaft weirdness. mech Defender Technical Discussions 4 April 15th, 2015 02:34 AM
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
Steering box swap 3 to 4 bolt? Chris Velardi Defender Technical Discussions 4 July 12th, 2011 07:46 PM
