stainless door top studs - Defender Source
Old May 8th, 2007, 12:09 AM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Anybody have a source for these?
Old May 8th, 2007, 01:31 AM
themaxx's Avatar
themaxx
Ade
94 ST
Get in touch with Matt Hurst http://www.defendersource.com/forum/...tainless+studs
or
http://www.roverparts.com/Parts/9784.cfm
Old May 8th, 2007, 05:43 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Matt doesn't have any more
Matt has sold all the sets he had.
Old May 8th, 2007, 07:39 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
AB used to have them.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 8th, 2007, 08:01 PM
mattdh's Avatar
mattdh
Matt Hurst
jim- if i could get 5 more guys in on this i would do another run on them
Old May 8th, 2007, 08:33 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Are the ones Matt does tapered or just like the stock ones except SS. If they are like the stock ones I'm in.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old May 9th, 2007, 12:02 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Ditto what Joe said
Old May 9th, 2007, 01:20 AM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Why would you go with stock over tapered? Tapered seems to be the better solution that doesn't require the sleeve. Am I missing something?
Old May 9th, 2007, 09:35 AM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I bought from Matt, and they look and work great. I bought the sleeves to put in and they do absolutely no good. It makes no difference with or without sleeves.
Old May 9th, 2007, 10:34 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I was under the impression they would rattle without the sleeves. Did you crank them down tight enough?
Old May 9th, 2007, 11:35 AM
Joe P's Avatar
Joe P
Joe Pfeiffer
I bought the tapered ones, but when I installed them they didn't line up with the holes in the door bottoms. I don't use the sleeves either. They rattle a little, but th esleeves a PITA, adn liek I said the hoels don't line up properly on my D-90.
Old May 9th, 2007, 02:54 PM
I've got one truck with Matt's stainless studs and no sleeves, before that it had tapered studs with no sleeves. The tops dont rattle with either and I cannot detect any functional difference betwen the two except for the fact that the stainless ones dont rust and turn into crap.
The other truck has tapered studs and sleeves. The tops are hell to get off and dont tighten down to allow a nice door seal.
As far as I'm concerned, sleeves are a function inhibitor.
Old May 9th, 2007, 03:10 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Maybe you guys can clear something up for me. I bought new door top studs from RN and put them in my 97 ST. The ones I took out were tapered also. But, when I was ordering, I saw that I needed sleeves ( or thought I did anyway ), so I ordered 4 of them. I assume now that tapered do not require any sleeves, and there must have been an untapered door stud at some point that required these. So, was the tapered thing an upgrade at some point? I have not seen any regular door top studs that require the sleeves when shopping around.
Also, the PO bought the quick connect nuts. I installed the door top studs and new seals on my door top and gave the truck a wash. When I went to remove the windows shortly after the quick connects were filled with water. This seems to be just asking for rust on the new door top studs. I was thinking about drilling a small drain hole in them, but then the water would drain back behind the door panel. Has anyone else had a similar experience?
Old May 9th, 2007, 03:49 PM
Yes, short of drilling holes, the holes are going to fill with water.
The tapered studs are OEM, the SS ones Matt had made are not tapered. Tapered, SS studs are available from Atlantic British, as are stainless quick nuts. The advantage of Matts studs (sure glad he isnt making nuts) is that they are less than half the cost of the AB ones.
Dont get quick nuts from Rovers North. They are either not stainless or made from really low-grade stainless and they rust like crazy. They suck.
I think the best thing to do is to take the quick nuts off every now and then and let the holes drain out.
Old May 9th, 2007, 04:02 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
OK, show of hands. How many are in for a set of Matt's stainless studs?
I'm #1.
Old May 9th, 2007, 05:45 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
#2
BTW - the original studs are not tapered they are straight and meant to be used with the sleeves.
Old May 9th, 2007, 07:45 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Old May 9th, 2007, 08:14 PM
cellulararrest
Chris Snyder
#4 Why not?
Old May 9th, 2007, 08:16 PM
hartman
Edward Hartman
1997 D-90
#5, I was in the market anyway!
Old May 9th, 2007, 08:49 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
#6 I am in for a set.
Gary
door
stainless steel studs for st doors mattdh For Sale - Parts 141 December 15th, 2011 09:20 AM
Stainless Window Studs and Speed Nuts Wolf Fabrication For Sale - Parts 7 December 8th, 2011 11:14 AM
Stainless Steel Window Studs Wolf Fabrication Wanted 3 March 26th, 2008 10:44 PM
stainless window studs mattdh Defender Technical Discussions 34 December 9th, 2005 08:19 PM
stainless steel studs forst doors mattdh For Sale - Parts 0 December 8th, 2005 07:13 PM
