Springs! - Defender Source
Old December 6th, 2010, 04:59 PM
Naplm00
Matthew
Exclamation Springs!
I need a set of springs, Ive got a 84 110.
My fronts are sagging, standard height would be nice if you have a whole set or a HD set with a lil lift. Id take a 2in set as long as i dont need to upgrade anything else.
Jusp looking to swap them in quickly.
Old December 6th, 2010, 05:05 PM
The 110 truck cab and vans came that way- higher in the rear so that when loaded they leveled out.
Old December 6th, 2010, 05:08 PM
Naplm00
Matthew
Yea but its just my driver side that is sagging.
Old December 6th, 2010, 08:33 PM
Try swapping with the passenger side?
Old December 6th, 2010, 08:37 PM
Naplm00
Matthew
Then that side will e sagging
Old December 6th, 2010, 08:38 PM
Not necessarily. One side of the truck is heavier than the other and it may even it out.
Old December 6th, 2010, 09:15 PM
Naplm00
Matthew
Agreed that may be a possibility, but if im in there id just like to replace them. I figured someone would have a set lying around after a upgrade to lift
Old December 6th, 2010, 11:51 PM
andyrad
Andy Radlgruber
None.
I have a pair of RR3-3 but it'll cost an arm and a leg to ship them cross country.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old December 7th, 2010, 12:51 AM
Naplm00
Matthew
what are rr-r3? Im new to lr
Old December 7th, 2010, 11:50 AM
Rovertym Engineering springs
http://www.rovertym.com/
Old December 7th, 2010, 12:52 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'll have the ones off my 1983 110 available in a few weeks, all sand blasted and ready for paint. Seem to be in OK shape. Ron or Doug may be able to comment on condition.
Old December 7th, 2010, 01:10 PM
Naplm00
Matthew
That sounds good, im local to you as well. Does your truck sit level or lean towards the front?
Old December 7th, 2010, 01:52 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
FWIW my drivers side is taller than passenger side
Old December 7th, 2010, 01:54 PM
Naplm00
Matthew
wierd, Just does not make sense to me, driving down the road or the truck vacant and it sitting at 3-4 degrees off center up front...
just looks broken
Old December 7th, 2010, 02:12 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just dropped the engine and tranny back on the frame so I'll take a pic. Ron had the truck as one piece so he can probably answer that ?
Old December 7th, 2010, 02:21 PM
LRover's Avatar
LRover
J. Michael McCaig
For years Rover coil springs were "handed". The driver's side spring is a shade stiffer so that the vehicle sits level with the driver.
Old December 7th, 2010, 02:23 PM
Naplm00
Matthew
ah gotcha, min is RHD and it sits lower on that side with or without someone in the cab
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
