Speedo cable retainer clip - Defender Source
Old October 6th, 2014, 08:06 AM
Misplaced the one I thought I had...need the little two prong clip that holds the speedo cable housing into the LT230. UNLESS someone can tell me how to adapt the Disco LT230 speedo sender to work with the RRC?
Old October 6th, 2014, 10:25 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We've got them - back in the shop tomorrow...
Old October 6th, 2014, 12:43 PM
Yup I have the sender in there. This is on the tay-hass truck with the LT230 conversion. It won't pass Maryland inspection with a no-worky speed thermometer.
The electriciful sender appears to have two wires on a flat oval plug, so that has to connect with the round 3 wire plug. I can fab a pigtail, but it's easier to fit the old RRC one than to make a cable.
Old October 6th, 2014, 12:50 PM
The connector is the same as Defender brake lights, STC4637. The middle wire is not used. I would doubt the frequency of the signal is the same though. You would need an electronic speedo correction box.
Old October 6th, 2014, 01:25 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Then just like the disco front turn signals?
Old October 6th, 2014, 01:51 PM
I don't know, but would think the turn signals are the 2 wire plugs, STC1188 which are not what are used for the speed sender.
Old October 6th, 2014, 02:14 PM
crown14's Avatar
crown14
Verticalscrote
I see what you're saying
speedo
part search - door linkage rod clip/retainer RRC corrumpu Defender Technical Discussions 8 July 29th, 2014 12:41 PM
coolant line retainer clip.. kevincdoyle Wanted 5 July 27th, 2014 09:31 AM
Solid Bonnet Prop Rod and Retainer Clip Miller Wanted 3 October 19th, 2012 08:49 PM
Stock Speedo retainer clamp and nut wanted Manimal Wanted 1 July 28th, 2011 09:29 PM
Bonnet Release Cable Clip -- Please Help! jefhuf Defender Technical Discussions 4 June 19th, 2010 10:55 PM
