Snorkel - Wing top mounted style - Defender Source
Old May 12th, 2016, 09:02 AM
flyfish's Avatar
flyfish
Todd Burnett
84 110, 95 SWB
Looking for a wing top mounted snorkel for a left-hand drive defender.
Thank you.
Old May 12th, 2016, 09:50 AM
Erik@Lucky8's Avatar
Erik@Lucky8
Erik
1985 D110 Ex-MOD & a few others
Contact Zack at Rovers North, I believe they can still source them
RAISED AIR INTAKE DEFENDER NAS V8 LHD GALVANISED + POWDER COATED, RNA1002 - Rovers North - Classic Land Rover Parts
Current:
2007 Range Rover L322 - 4.4L HSE LUX
2003 D2 - Monte Carlo Blue 2" TF lift
1991 RRC Hunter - 2" OME
1985 D110 EX-MOD
Gone:
2006 LR3
2004 D2
2001 D2
2001 D2 - Lucky8 Project D2 - REDUX
2000 D2 - Trail Project, maybe
1999 P38
1995 RRC LWB
Old May 12th, 2016, 07:50 PM
flyfish's Avatar
flyfish
Todd Burnett
84 110, 95 SWB
Appreciate that man! Yep, I believe it's a Mantec design. Just figured I'd see if anyone had a used one first.
Old May 12th, 2016, 09:20 PM
One of these will work for you
SP Landrovers LTD- Land rover Body Panel and Door Specialists
Old May 12th, 2016, 09:40 PM
Naplm00
Matthew
Prepare your wallet...
Old May 13th, 2016, 08:37 AM
flyfish's Avatar
flyfish
Todd Burnett
84 110, 95 SWB
Originally Posted by Rocky View Post
That link comes up as an error and didn't see a wing top option on their site. Let me know if I missed something. Appreciate the help!
Old May 13th, 2016, 08:39 AM
TNRoverGuy's Avatar
TNRoverGuy
Chris H.
'97 NAS D90 ST
I don't think you're missing anything. They have lots of intake options, but none for an NAS V8 truck (which would be the wingtop mounted kit).
If you hang around they pop up on here about once a month. In the past six months, snorkels have sold from $75 to $400 here on the board.
Old May 13th, 2016, 04:22 PM
flyfish's Avatar
flyfish
Todd Burnett
84 110, 95 SWB
I was a hair late on that last one. Thanks again!
Old October 4th, 2016, 05:29 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Hey Todd,
I know you were looking in May but just saw this post. Not sure if you got one yet? I have a Raised air intake for a LHD NAS Defender. It's a complete kit and only used for 6 months before being removed. It's been in a box for the last 18 months. I'm posting it tonight but figured I would send a post just to check. The asking price is 400. or BO plus ship
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old October 4th, 2016, 06:05 PM
DocB
David
1989 D110
I just built my own, cost probably $50-75. Let me know if you want to chat about how to do it!
ID:	159052   Click image for larger version
ID:	159054   Click image for larger version
Old October 4th, 2016, 06:06 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
For what it is worth, I had a muffler shop bend me up one for my truck and I cut a piece of steel for the wing top vent and welded that on. I got a mantec style mushroom cap from ebay for $40. Total for everything was about $100. Just another option--I know not everyone has access to a welder.
Old October 4th, 2016, 06:34 PM
roverx's Avatar
roverx
Scott Preston
Nice Job! I have built at least a Doz raised air intakes over the years. This is a total factory kit and for someone who wants to keep their truck factory original. I have a tdi hybrid and have already built a new one and had it hot dipped. Just trying to decide what type of cap I'm going to use. I'm leaning towards a tractor version I can get at the Case dealer. I debated modifying this one to make it work for my needs but in the end didn't want to screw with a nice unmolested part.
Cheers,
Scott Preston
Old October 4th, 2016, 07:27 PM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
I'm definitely interested in hearing about your DIY.
In terms of sourcing the parts and any relocation/modification needed to the truck!
Thanks!
Old October 5th, 2016, 04:45 PM
DocB
David
1989 D110
Thanks!
Basically I looked at all the kit online and figured that I could do it much cheaper. I started at Autozone and found a 3" flexible tubing kit that I used to go through the fender. I removed the stock plastic cover piece and cut a 3" whole in the middle with a dremel. I took some left over fuel tubing, made a slit in it lengthwise, and fit it around the rough cut that I just made as a gasket of sorts. The tubing kit was conveniently threaded, so I spun it into the new whole that I made until it was at the desired length. I connected this to the air box under the hood with some vacuum cleaner hose. The top part is just some PVC pine that I found, and the breather head is like $16 on Amazon. I connected all of it with band clamps. The only part of the whole set up that was from a snorkel originally is the mounts that connect it to the frame of the car.
I hope you get the idea! I can make a D.I.Y. post with photos also if there's interest.
Old October 5th, 2016, 05:01 PM
If you want a "nice" homemade solution, without spending a lot, pickup a Southdown wing moulding and bend your own tube and supply your own hose.
http://stores.ebay.ca/Southdown-4x4-...p2047675.l2563
Old October 6th, 2016, 11:08 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I thought shitter-pipe snorkels were out of fashion these days??
Where is JSQ?
Rent my
mount, snorkel, top, wing
RHD NAS Like Wing Top Mounted Snorkle FS SafariHP The Vendors Loft 1 December 4th, 2015 12:41 AM
Mantec v8 wing vent mounted snorkel Landyman1 Wanted 0 November 10th, 2013 05:41 PM
Wing Top Snorkel for 300Tdi CMSgt Bo Wanted 3 December 21st, 2012 03:43 PM
Snorkel top, Air filter assembly, TDI Snorkel side intake pmd For Sale - Parts 10 March 1st, 2012 12:04 AM
Wing top Snorkel mounting 1995 d-90 3.9/petrol Overland90 Defender Technical Discussions 3 September 11th, 2008 04:58 PM
