Small Tach Gauge For 200TDI - Defender Source
Old April 16th, 2011, 03:02 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I have an '84 d-90 with a 200 tdi disco motor. My cluster of gauges on this right hand drive rig includes the speedo, the temp. gauge and the fuel gauge. The far right small opening in my instrument cluster has a factory "blank" in it. I've seen some of these instrument clusters with a tachometer in that spot. I would like to add one. Does anyone have a proper LR tach hanging around or can you suggest a source. Would the tach have to be from a 200tdi to work properly?
Thanks in Advance for any info,
Old April 16th, 2011, 04:39 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Put a VDO vision black in my 1984 90" with a defender 200tdi it looks pretty much stock other than it is brighter than the stock ones
http://www.egauges.com/vdo_grou.asp?Series=Vision
Old April 16th, 2011, 04:53 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Ditto, I just did it on my 110, looks perfect
There's a pic in my 110 build
You could also go clock. But the tach is only like $75 and hooks up to the post on back of the alt marked W
Old April 16th, 2011, 05:08 PM
Yes, just get a VDO. The only downside is that you will want to replace the rest of them because they are so much nicer..
http://members.shaw.ca/red90/maingauges.jpg
Old April 16th, 2011, 05:43 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
The VDO fuel gauge works on the original sender for the older tanks like ours and the temp is a simple sender swap. I just ordered them last week, I think they were $25 each
The temp sender was $43.
Old April 16th, 2011, 09:15 PM
isleofbones
Mike Deery
1984 D-90
Thanks guys... I think I'll get the VDO gauge. But, which one of the ones listed is the correct one Dave?
Old April 17th, 2011, 04:44 AM
Any 2-1/16" one will fit. 333-156 (for 4000 rpm) or 333-158 (for 6000 rpm).
Old April 20th, 2011, 12:14 PM
discotdi
Todd Miller
Land Rover
So you have to buy the wiring harness also to use with guage 333 156??
Old April 20th, 2011, 03:43 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just ran my own
Old April 20th, 2011, 09:48 PM
discotdi
Todd Miller
Land Rover
Cool thx Tom
Old April 21st, 2011, 08:10 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On the diesel the tach will run off the alternator. You need to make sure that the Alternator has the post, center bottom. Like the others I used the VDO 52mm gauge, 133-156. You can use the light connection from the old clock if fitted or run a jumper from one of the other gauge lights. You will also need to run an electrical wire to the Alternator and one for a ground. The gauge fits perfect in the dash. The gauge does have an adjustment in the back but I forget what notch I left mine on. Maybe some others can pipe up on that. The other guys are 100% correct about the brightness of the new Tach, it will be much brighter than the other gauges.
Land Rover 110
200tdi, ac, tdi
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
tach question, sorry if redundant (warning) Neo Defender Technical Discussions 5 October 7th, 2005 04:24 PM
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
