Side Marker Light - 110 - Defender Source
Old December 28th, 2009, 05:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
The drivers side rear side marker light burnt out in my 110. I pulled the bulb from the inside to see it was full of water and corroded. Does anyone have the lamp plug the bulb goes in to? I want to replace this one.
Name:	drivers side light.jpg
Old December 29th, 2009, 12:36 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
The marker lights on the 110s and early 90s were made by Trucklite. You can find them at NAPA or other fleet retailer. P/N 18050R is the LED replacement for that light.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 29th, 2009, 12:49 AM
Or $7.50 each at RDS. I think I have barry sorted as I need a lense and he needs a bulb holder.
Old December 29th, 2009, 01:00 AM
bjf's Avatar
bjf
barry f
94 ST #395
How is the LED one? Wouldn't mind one that doesn't rot
Old December 29th, 2009, 01:11 AM
Roadsiderob
Robert Dassler
1994 D90
I've been running the LED markerlights for 8ish years now. I like them. They are more expensive but are completely sealed. If you go that route remember to use good waterproof wire connections. And remember white is ground and black is power....they don't work the other way.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 29th, 2009, 01:30 AM
bjf's Avatar
bjf
barry f
94 ST #395
Well only one of mine is shot but I am a believer in fix it once. OK that is a lie. Does the light pattern look different?
Old December 29th, 2009, 01:48 AM
They are $18 and change each from Ryder truck parts. You would need bullet connectors too so figure an extra $1 for each light.
Old December 29th, 2009, 01:50 AM
Roadsiderob
Robert Dassler
1994 D90
No, the light looks about the same...it's not obvious that is an LED unless you look carefully. Trucklite offers both the LED and bulb style lights and they are available from NAPA and other fleet retailers. These lights are used as marker and clearance lights on transit buses and other stuff. The NAS 110s and early 90s used these lights. Later production switched to lights like the Discos used.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
110, ht
Right side rear side marker light Jamie Deck Wanted 1 October 31st, 2009 09:50 AM
110 Rear Light Assembly Ron Thompson Wanted 0 August 22nd, 2005 02:13 PM
Side Marker Bulb Replacement Matt Klapmust Defender Technical Discussions 8 December 23rd, 2004 06:09 PM
front fender side light alaskajgg Wanted 3 November 18th, 2004 11:01 AM
