Seat Box Battery Lid - Defender Source
Old October 23rd, 2012, 05:26 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I need a Seat Box Lid for the battery compartment. Left side. The skinny one. ~10" wide or so. Anybody got one?
Chance
Old October 23rd, 2012, 05:50 PM
Lemonhead
TB
1997 D90 SW
PM'd you.
Old October 23rd, 2012, 05:59 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Safari HP has them new, also
-Ren Ching
Old October 23rd, 2012, 06:43 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We have the YRM seat-box lid kits in stock as well
Old October 23rd, 2012, 07:29 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I need both sides. Can you explain why the YRM is a "kit"? Is there something to put together??
thanks
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old October 23rd, 2012, 07:38 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
link to the YRM page here
Land Rover Defender Seat Box Lid Replacement
YRM parts used for Land Rover Defender Under Seat Toolbox Compartment Lid Replacement are,
1no. 137 Land Rover Defender Seat Box Lid Kit
Picture no.1 shows how you will receive your seat box lid kit.
Picture no.2 & 3 show the toolbox empty or your fuel tank maybe there. Next you need to transfer lines of the widest point of the seatbox opening to locate where the angles need positioning.
Picture no.4, 5 & 6 sit the lid in position ensuring the seat box catch is located in the lid slot and transfer lines of opening onto aluminium lid.
Picture no.7 & 8 measure the width of the opening at the front and back to see if it parallel, also fit to the angle 5mm narrower so it’s not too tight for fitting.
Picture no.9 shows the lines transferred around to the underside of the lid making sure the the marks are 5mm narrower than opening.
Picture no.10 & 11 measure back from the front of the toolbox compartment, then transfer these measurements onto the lid, this is so the angle doesn’t catch the seat box comparment.
Picture no.12, 13 & 14 mark the angle were you are going to locate rivets using a 4.9mm diameter drill bit, then position and clamp the angle in place then drill through and remove any rag and rivet in position.
Picture no. 15 repeat process for fitting angle on the other side.
Picture no. 16 offer in place to make sure it fits.
Picture no. 17, 18 & 19 remove the bolts and measure cross centres to hold toolbox lid retainer, to stop the lid from rattling.
Picture no. 20 & 21 mark and drill holes on lid retainer, they will need to be 7mm diameter holes to take the M6 bolts provided. Then bolt in place.
Picture no. 22 The angles are positioned differently here to accommodate different widths of the opening of the compartments.
Picture no. 23 & 24 apply foam tape to the underside of lid around the outside of angles where the lid sits on the seat box compartment to kill any vibration noise. Then remove protective film from the lid and fit and repeat for the process for the other side.
Old October 24th, 2012, 09:44 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Got one. Thanks everybody!
Chance
Old October 24th, 2012, 10:27 AM
Reese_D90's Avatar
Reese_D90
Reese
I need both sides. Anyone go any laying around?
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
battery, seat box
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Need Ac Vent And Cover Seat Base Over Battery FREEDOM Wanted 2 May 29th, 2005 12:19 AM
Bedliner on the Seat Box JimC Misc. Chit-Chat 0 February 19th, 2005 08:14 PM
