Salisbury Rear Axle - Defender Source
Old February 25th, 2010, 07:55 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Salisbury Rear Axle
Anyone have a decent 110 Salisbury rear axle lying around???
Semper Fi!
Old February 25th, 2010, 08:10 AM
if you can wait a few weeks I'll have one avail.
Old February 25th, 2010, 08:13 AM
Wolf Fabrication
Sterling Archer
'08 D3
Any idea the condition? Does it happen to have disc brakes (I know, a long shot).
I have a Disco rear axle now and am upgrading to 24 spline shafts. I just ordered some ARBs, but now am thinking maybe I should put in the correct axle.
How strong is a stock Salisbury compared to a Disco rear axle with HD 24 spline shafts?
Semper Fi!
Old February 25th, 2010, 08:31 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Shafts are the same strength with 24 spline
The ring and pinion are stronger on the sals since they are pretty much the same as a Dana 60
Sals is able to be built to a higher level than the standard rover diff since you can bore it out and add larger 35 spline axles
gears and lockers will also be less since you can purchase Dana 60 stuff
Contact Keith at Rover Tracks and he can give you all of the options
http://www.rovertracks.com/products/axles.html
Old February 25th, 2010, 10:52 AM
To build a proper salisbury (IMHO) you need disc brake brackets ($100X2) and I would suggest new shafts and drive flanges (~$400) (you can mill down the brackets and use the factory shafts) and, if you mill down, RRC non-ABS hubs or if you use new shafts, ABS hubs, stub axles etc.
Then you need standard pads, rotors and calipers.
So, it is not a cheap proposition. OTOH, the Detroit is fairly inexpensive for a sals.
Old February 25th, 2010, 02:56 PM
Drum brakes. All disco axles already have 24 splines....what you talking bout Willis ?
Old February 25th, 2010, 02:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
Maybe US Discos starting in 1994 were 24 spline. My '92 UK Disco axles are 10 spline.
Semper Fi!
Old February 25th, 2010, 03:15 PM
Mid 1993 was the cut off from 10-24.
BTW does your disco axle have ABS? if not, the ABS 24 spline axles might not fit.
Old February 25th, 2010, 03:43 PM
Wolf Fabrication
Sterling Archer
'08 D3
Nope, no ABS for me!
Semper Fi!
Old February 25th, 2010, 03:46 PM
You need to find out if you have ABS style hubs or not.
Actually, just toss the whole axle and go salisbury. Or toss it and go with a donor 94 and up RRC/D90/D1 axle.
Old February 25th, 2010, 06:24 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
I have a rear disk Salisbury missing the calipers if you’re interested shoot am a PM with an offer. I can shot pictures if you like.
Jetmech
Old February 25th, 2010, 06:57 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, but shipping would be a bitch. I'm hoping for one close by.
Semper Fi!
Old February 25th, 2010, 09:05 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Talk to Mike at ECR, he has posted them for cheap on here in the past and it is not toooo far of a drive.
axle
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
