Salisbury Half Shafts/Flanges Wanted - Defender Source
Old March 1st, 2012, 08:59 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Need both half shafts and drive flanges to a Salisbury rear end.
I think the half shaft part number is FRC8095 and drive flange is FRC5806
As an alternative - I'd also consider buying an entire axle/diff assembly that was compatible with a '85 110. I don't think I necessarily absolutely need a Salisbury rear end or any lockers for the type of driving I do. I'd probably be better off upgrading to a late-model rear end with disk brakes if I were going to swap the entire axle. I'd need this to be somewhat local within New England otherwise shipping would kill this.
PM me.
Old March 1st, 2012, 10:07 AM
ItsNotAJeepThing's Avatar
ItsNotAJeepThing
Charles Essex
1995 Disco
Mud Ruts had some Salisbury gbr shafts and flanges i believe, send him a pm on dweb
Old March 5th, 2012, 09:36 PM
Roving Beetle
Doug
I have a full drum brake Sals rear, in Maine, low miles - Was on a coiler 110.
I would sell it very reasonably at this point as I simply don't need it. Can part it out I suppose to save on shipping. PM and offer or trades!
Doug
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old March 5th, 2012, 09:48 PM
PM me.
I'd say stick with the Sals...it's a hell of a rear end, and will only help your resale value down the road.
Old March 5th, 2012, 09:54 PM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
If you want new I have the HD version of the flanges in stock. I can also get the stock one for you by next monday.
HD kit is $92 for a pair.
stock is $21 for the set
The part number for the shafts is coming up to fit a 4 pinion diff.
If you need them they are $41 each side
For expedition tested Rover gear Check out
716-898-8153
Old March 5th, 2012, 09:59 PM
Roving Beetle
Doug
Wow, those are cheap..... how much is an ARB for one? Is it available these days?
Old March 5th, 2012, 11:04 PM
Jackie Treehorn
A
1985 (legitimately)
Justin, are those the hubs with the anodized looking finish and the pentagon hub cover?
I'll double check the axle part number before ordering.
Wish I had known this on Friday before we decided to re-weld the ones on there (I know, that's absolutely budge! and not the correct solution). I just needed to get the thing back from the shop. They are easy enough to swap out, right? so having the correct set on hand for when these welds fail would be nice.
Doug, thanks for the offer to part out the Sals. If it comes to that I will definately take you up on that, but the new ones are the way to go I think.
Jason, yeah I have thought about it an basically agree that I should stick with the Sals. Even though I'm not doing any heavy wheeling and don't have lockers etc., I do have some extra weight and end up in the soft sand quite a bit (that's probably more load that towing).
Old March 7th, 2012, 10:43 PM
Fivespddisco
Justin Monnin
96 D1
The ARBs are around $1000 I have one in stock
------ Follow up post added March 7th, 2012 10:45 PM ------
The HD hubs are anodized ones you are thinking of.
716-898-8153
Old March 7th, 2012, 11:49 PM
Jackie Treehorn
A
1985 (legitimately)
Justin, thanks for your help.
I'll be ordering these soon, but in all candor am still licking my wounds (financially) after an ever-growing list of things needed to be sorted out.
If I were to order the half shafts (both sides) and OEM drive flanges, are there any special part numbers or information you'd need other than the fact that it's a Salisbury? do you need a serial number off of the axle or are they all basically the same in terms of half shafts/drive flanges?
I'm in no hurry and would be looking for sometime before next month probably.
Old March 8th, 2012, 06:46 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have several sets of axles collecting dust. Not sure about drive flanges but sure I have them also (will confirm). $50 p/u only .....Eliot Me, not far from Duxbury.
I've been installing I piece versions that Keith www.rovingtracks.com made for me. Eliminates the drive flange issue.
Matt Browne
Old March 8th, 2012, 09:16 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Just checked and have 2 sets of axles and 1 1/2 sets of flanges.
Matt Browne
WANTED - Factory Bumper! Stmpede Wanted 0 March 8th, 2007 12:22 AM
Wanted to Trade Disco or SE Tow Vehicle racerbvd Wanted 0 February 19th, 2006 02:28 PM
Wanted to Trade Disco or SE Tow Vehicle racerbvd For Sale - Vehicles 0 February 19th, 2006 02:23 PM
Wanted - Defender 90 - Wanted 94-97 geneseemtn Wanted 1 January 3rd, 2006 09:19 AM
Badger Half Cab Pricing boshea Misc. Chit-Chat 3 November 6th, 2003 03:22 PM
