Salisbury drum brake parts - Defender Source
Old September 2nd, 2012, 10:01 PM
Abrooks's Avatar
Abrooks
Tony Brooks
The bleeder hole on my right wheel has stripped. Does anyone have that component left over from a disc conversion?
Old September 2nd, 2012, 10:54 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Are you talking about the wheel cylinder?
1970 SIIA 88, Sold
Old September 3rd, 2012, 10:30 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Yup I believe that is the next larger component that holds the bleeder.
Old September 3rd, 2012, 10:04 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I'll take as much of the brake assembly as someone's willing to get rid of. . .
Old September 3rd, 2012, 10:11 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I have most of it, except for the RH backing plate. It's all yours for the price of shipping.
1970 SIIA 88, Sold
Old September 3rd, 2012, 10:16 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Is the backing plate the piece that the bleed screw screws in to?
Old September 3rd, 2012, 10:35 PM
grnrvrs's Avatar
grnrvrs
Paul
88
No. The bleed screw, screws into the wheel cylinder, which is bolted to the backing plate. It sounds like you need a new cylinder. While my old cylinders were in working order when I started the project, I would not recommend them (or any used brake cylinders) unless you were planning on rebuilding them with liners.
1970 SIIA 88, Sold
Old September 3rd, 2012, 10:47 PM
Abrooks's Avatar
Abrooks
Tony Brooks
You're very likely right. Let me see if I can come up with a part number.
Old September 4th, 2012, 05:46 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Does it look like this? RTC3626
1970 SIIA 88, Sold
Old September 4th, 2012, 05:54 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Tony, I also have a comlete set of everything left over from a disc brake conversion, including half shafts, if you should need anything else. Certainly agree, new wheel cylinders are cheap enough....
Email is
Same place, new dogs.
Old September 4th, 2012, 06:45 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Yup, that's the right one! Ordered it from safarihp today. Also woun up getting a full set of shoes from BP. Prices for each fluctuated massively across vendors.
brake, part, parts
Series I II IIa III Heystee disc brake conversion kit kullberg Series Technical Discussions 8 June 14th, 2012 03:42 PM
Turning the Brake Drum? ]-[ @ n $ Defender Technical Discussions 6 February 28th, 2012 09:26 AM
Salisbury drum brake rear axle assembly Uncle Douglas For Sale - Parts 0 December 15th, 2010 07:39 PM
FS Salisbury Drum Brake Parts Stmpede For Sale - Parts 3 December 18th, 2008 08:02 PM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
