RRC Wanted - Page 3 - Defender Source
Old July 18th, 2012, 03:59 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Hard to beat this one, 1 owner with all records and "no rust": http://cgi.ebay.com/ebaymotors/1989-...item3f19da4b14
Old July 18th, 2012, 04:34 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Wow, that one isn't bad!
Semper Fi!
Old July 18th, 2012, 04:53 PM
It's close to me too... If you need to buy it.
Old July 18th, 2012, 06:47 PM
"Last of the British Made Rovers."
Where do people come up with this crap?
Old July 20th, 2012, 07:37 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If there is ANY rust in the door jamb the body is toast too.
Old July 21st, 2012, 03:17 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
http://denver.craigslist.org/cto/3052020309.html
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old July 21st, 2012, 06:09 AM
Wolf Fabrication
Sterling Archer
'08 D3
oooooo, sex on wheels. Me likey!
Semper Fi!
Old July 21st, 2012, 07:20 AM
that 92 is sweet, LSE top of the line right?
Old July 21st, 2012, 09:36 AM
Wolf Fabrication
Sterling Archer
'08 D3
Bought that '94 in MD. Nice, solid truck, a few gremlins to address. Pics forthcoming.
Semper Fi!
Old July 21st, 2012, 11:29 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Nice! what are you going to do with the front bumper? What are you going to set the truck up for?
Old July 21st, 2012, 11:55 AM
Wolf Fabrication
Sterling Archer
'08 D3
Not sure about the bumper. It's a non-winch bumper, so I may look at modifying it or selling it.
The truck is pretty well set up with 4.11 gears, lockers, and spring conversion with 2" lift. I'll probably look at sliders, diff guards, and a winch, that's about it! Then just mild to medium wheeling.
Semper Fi!
Old July 21st, 2012, 02:09 PM
Abrooks's Avatar
Abrooks
Tony Brooks
You're welcome
Old July 21st, 2012, 02:34 PM
Wolf Fabrication
Sterling Archer
'08 D3
5 year old checking out his new ride.
Semper Fi!
Old July 21st, 2012, 02:37 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Abrooks View Post
You're welcome
While I know you'd like to take credit for finding, I did find it first. I didn't contact the guy initially because he didn't post any pics.
I went over the truck once I got it home. ZERO body rust, with the exception of some scale forming in the tailgate in the usual places.
I've got the ABS light on which I am told is the accumulator, and the check engine light which several known Rover shops can't get to go away.
Semper Fi!
Old July 21st, 2012, 04:22 PM
Bill Larson
Bill Larson
Nice truck Wolf...I love the profile of that model.
Old July 21st, 2012, 04:40 PM
Maybe. Is it the barbell looking light or the ABS light? The Barbell looking icon is the traction control light and it can come on if the brake pad wear sensor wire has come off, which is a fairly common thing.
The ABS light means one thing: low pump pressure, which means big bill is coming for a visit.
CEL light is one of those weird things that just never seems to die once it comes on. Usually it is from bad HEGOS. I have replaced them only to have the light stay on. Only Rovacom can turn it off by clearing the codes. On the last truck I had I just took the idiot light bulb loose from the back of the binnacle.
Old July 21st, 2012, 04:49 PM
Wolf Fabrication
Sterling Archer
'08 D3
It's both. The ABS light can be the pump, accumulator, check valve, or sensors. I did the diagnosis and the pump is fine and appears to be the check valve or a leak.
That's what I plan on doing.
By the way, do these trucks have the LED computer readout for the check engine codes like the D-90s do? Where's the computer anyway?
Semper Fi!
Old July 21st, 2012, 05:44 PM
To see the readout, you must remove the outer plastic seat box trim on the passenger side.
It's prolly a 44,
------ Follow up post added July 21st, 2012 05:46 PM ------
I'd be tempted to kill the ABS
Old July 21st, 2012, 05:53 PM
That looks like an ARB winch bumper to me. Jus no winch installed.
Old July 21st, 2012, 07:11 PM
Wolf Fabrication
Sterling Archer
'08 D3
You are correct! I hadn't looked closely at it. Even better.
------ Follow up post added July 21st, 2012 07:14 PM ------
It's prolly a 44,
Found it, thanks!!! I need to cut a hole in the trim panel for next time.
It's a 45, which can be a ton of little things as you know. It is running rough and stinky, so I am going to start with a fuel filter and work my way through the usual areas.
I did the diagnostic - it's flashing a 2-8 code which is "no voltage to ABS solenoid valves, faulty valve relay AB14 or wiring"
The Traction Control light was on because the PO removed the ABS fuse.
Semper Fi!
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
Wanted RRC Beater JBurt Wanted 17 December 4th, 2006 09:34 PM
Wanted to Trade Disco or SE Tow Vehicle racerbvd Wanted 0 February 19th, 2006 02:28 PM
Wanted RRC SWB dave_lucas Wanted 4 October 18th, 2005 03:24 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
