RRC rear light guard clips part - Defender Source
Old July 15th, 2014, 10:49 AM
KSARover110's Avatar
KSARover110
Dan
1983 Rover 110
Does anyone have the screw clips that hold the guards to the taillight? Or know where to get them. Not the rubber housing on the side.
Old July 15th, 2014, 01:44 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Attachment 98802
IIRC It is just a plastic spacer, and you use a longer than stock screw.
Old July 15th, 2014, 02:11 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes, it's just a spacer and a longer than stock screw.
Rent my
Old July 15th, 2014, 02:25 PM
KSARover110
Dan
1983 Rover 110
Yes, it's just a spacer and a longer than stock screw. .
Thx for that...just pulled my set from garage and they are hinged
Old July 15th, 2014, 10:19 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
The hinged ones attach differently, I've seen a couple of different types with different mounts. One type uses a plate that screws or rivets between the edge of the lamp housing and the tailgate and it's sort of an L shape with a mounting hole for the guard to attach to. You have something similar to this and are missing the mounts?
On the rubber mounted ones like in your picture, the plastic spacer has a threaded metal insert, there's a screw inside the spacer that goes through the lens and then an Allen screw goes into the spacer to attach the light guard to it. These metal inserts have a nasty habit of breaking free of the spacer causing the guard to fall off. I saw some for sale that someone machines out of billet aluminum that uses a single long screw as Nomar mentioned, but you could modify the original ones, or even make some with nylon bushings from the hardware store.
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old July 16th, 2014, 01:38 AM
KSARover110
Dan
1983 Rover 110
Originally Posted by TigerDan View Post
The hinged ones attach differently, I've seen a couple of different types with different mounts. One type uses a plate that screws or rivets between the edge of the lamp housing and the tailgate and it's sort of an L shape with a mounting hole for the guard to attach to. You have something similar to this and are missing the mounts? On the rubber mounted ones like in your picture, the plastic spacer has a threaded metal insert, there's a screw inside the spacer that goes through the lens and then an Allen screw goes into the spacer to attach the light guard to it. These metal inserts have a nasty habit of breaking free of the spacer causing the guard to fall off. I saw some for sale that someone machines out of billet aluminum that uses a single long screw as Nomar mentioned, but you could modify the original ones, or even make some with nylon bushings from the hardware store.
Dan
Yes probably confused things with that pic. I have a set that you described with the plate (L shape) attaching to the edge of the light housing but my RRC has the rubber mounts attached. Do the hinged part attach to the rubber mount or am I missing different hardware?
Old July 16th, 2014, 01:57 AM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
No, take the rubber mounts off and attach the hinge in about the same area. I doubt the existing holes will line up, you'll probably have to drill new ones.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Rotating Shackle "Hoist Ring" Retaining Clips (Safari Guard Style) KKilo23 Wanted 39 May 17th, 2014 10:29 PM
rear cargo clips bjf Wanted 5 December 30th, 2009 02:00 AM
The two clips that the rear tailgate bar snaps onto and vertical rods for softtop evilfij Wanted 7 February 23rd, 2009 03:27 PM
WTB Rear window bar plastic clips d90boy Wanted 2 June 5th, 2007 10:34 AM
part #'s for clips mattdh Defender Technical Discussions 5 October 10th, 2003 10:13 AM
