Rover 727 aka Hen's Teeth - Defender Source
Old August 2nd, 2013, 07:34 PM
The Dro
Dro
1988 Ninety
Folks...
I'm looking for the Rover Torqueflite 727 Transmission and LT230, 1.003 ratio, transfercase that came in the 1982-1988 RRCs.
I already have the 727 motor adapter.
Let me know what you have.
Old August 5th, 2013, 12:30 PM
The Dro
Dro
1988 Ninety
I'll add some details.
I don't need a TF727, nor a LT230-1.003. I asked for them already mated, just in case I've missed a part here or there.
I already have a motor connected to the TF727. The tail housing I've got it's for a Dana/Spicer 20.
I'm looking for the TF727 tail housing with tail shaft and output shaft so I can connect the TF727 to the LT230.
Old August 5th, 2013, 01:03 PM
Hard to find is likely an understatement.
Ashcroft?
Didn't know they kept them until 1988.
Old August 5th, 2013, 01:49 PM
The Dro
Dro
1988 Ninety
Ashcroft?
I might be in luck... I found someone that has one. But it's not 100%.
I didn't see anything in Ashcroft's webpage. I'll drop them a line.
I got that info from the "interweb"... So it's got to be true.
Old August 5th, 2013, 02:13 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I think you messaged me on PBB?
I have everything but the output shaft for the trans. I was under the impression that it was a Jeep part but I am no longer certain. It may have been a 2 piece shaft that worked with the original IH output shaft.
That is a weird photo. A 727 behind an Isuzu?
JL
Old August 5th, 2013, 03:31 PM
jafir's Avatar
jafir
Jafir Elkurd
Here is a good post where Ian Ashcroft corrects some of my misunderstanding of how these 727 setups work. The most interesting pieces of the setup are how the engine to 727 adapter clocks the transmission a bit, the special pan, and the solid from driveshaft.
http://www.pirate4x4.com/forum/land-...350-rrc-2.html
Old August 5th, 2013, 03:47 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Another option you may want to look at is ditching the factory stuff and using a 727 Dodge tailhousing with an adapter plate and spud shaft to the LT230. I did this on my A518 (overdrive 727) equipped 109 to fit an LT230. Worked slick. Plus you could swap in the overdrive as well. I have a shaft I would sell you for 100 bucks, and the adapter plate is a snap to make. Then at least you would have an OD!
JL
Old August 5th, 2013, 03:53 PM
The Dro
Dro
1988 Ninety
JL, yes that was me.
Ohh crap, did I confused you with someone else?
Someone emailed me that they only had the tail housing.
Yes, that's an Isuzu diesel mated to the 727.
Anywhoo...
I'm waiting on an answer from the person that has the whole setup. He's somewhat local.
I'll read that post from Pirate
Old August 5th, 2013, 04:01 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I have the tail housing, the mounts, the shifter, the front driveshaft, and a bunch of other stuff. The T case I am keeping. As much as I'd like to see this stuff used, I think that some sort of an OD will be crucial.
I will take some pics now that I know what you are after.
So? Airport tug application?
JL
Old August 5th, 2013, 04:04 PM
The Dro
Dro
1988 Ninety
I'll PM you my email.
No. The TF727 was modiefied by Art Carr and was in a Scout.
Old August 5th, 2013, 04:22 PM
The Dro
Dro
1988 Ninety
BTW... I'm not 100% sure...
But I read that the IH and Rover have the same tail shaft.
If this is true, in theory I can use a Rover output shaft.
Yes, but in some circles we call it a 109"
Originally Posted by pendy
I'm here for the D's
Old August 5th, 2013, 04:29 PM
The Dro
Dro
1988 Ninety
------ Follow up post added August 5th, 2013 04:38 PM ------
If I got Ian's post right... I need to rotate the transmission 12deg and that's no bueno.
Old August 5th, 2013, 11:22 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have these parts stashed away if your local source does not come through.
legend in my own mind
Old August 6th, 2013, 10:34 AM
The Dro
Dro
1988 Ninety
Found this pic on Pirate.
It looks like the Rover TF727 has a Dana/Spicer 20 tail housing and an adapter plate to mate to the LT230.
Old August 6th, 2013, 10:53 AM
The Dro
Dro
1988 Ninety
Update: I got this today.
It looks like the IH Scout 2 tail housing I have will mate to the LT230 via this adapter.
ID:	77010   Click image for larger version
Old August 6th, 2013, 11:32 AM
Jeepers that set up is long. Your front drive shaft is going to be longer than the rear
Old August 6th, 2013, 12:25 PM
pendy's Avatar
pendy
jim pendleton
89'd90
727 is pretty short. I think it ends up being stock even with the bellhousing adapter
Old August 6th, 2013, 06:11 PM
The Dro
Dro
1988 Ninety
That's what I'm hoping.
Old August 6th, 2013, 08:18 PM
Rugbier's Avatar
Rugbier
Gustavo
I am wondering when I am picking up the 88.... LMAO*
NO SIGNATURE
2000 Range Rover 4.6 HSE for sale or trade for Defender treydub For Sale - Vehicles 6 February 28th, 2005 10:57 AM
1995 Range Rover 4.0 SE ember For Sale - Vehicles 2 January 24th, 2005 12:40 AM
Range Rover Sport on UK Website boshea Misc. Chit-Chat 1 December 27th, 2004 08:21 AM
The Greatest Rover Shop Ever Buckon37s Misc. Chit-Chat 2 December 22nd, 2004 01:00 PM
Land Rover Safari Rack! TwisteD90 For Sale - Parts 8 October 4th, 2003 07:48 PM
