Roll bar - Defender Source
Old November 4th, 2012, 11:59 PM
sro
Sam Odio
2008 LR2
Roll bar
Does anyone know where to get a rear roll bar?
Right now my defender is configured with only the front two roll bars (eg: http://c7743.r43.cf2.rackcdn.com/Ima...hoopset-02.jpg).
Can't find the rear-bar for sale anywhere.
Old November 5th, 2012, 12:47 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
It's commonly referred to as the "c-hoop" as it's the c pillar of the roll cage. You will also need the cantrails which are the lateral bars connecting the b-hoop to the c-hoop. These are no longer available (NLA) from land rover or Safety Devices, but occasionally they pop up used in the classifieds. Very rarely a brand new one in a box pops up for sale. There have been a few on ebay over the years but these are few and far between. Good luck on the search
Old November 5th, 2012, 01:13 AM
sro
Sam Odio
2008 LR2
Man, that's a disappointment. I wonder if anyone's tried to fabricate a set.
Old November 5th, 2012, 01:22 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Fabrication of the roll-bar itself would be relatively easy, I beleive it is made of 1 3/4" DOM .120 wall tubing. The problem is replicating the original molded foam. I don't think anyone has ever carried out re-making rubberized reproduction cages. You could do something other than the factory foam such as a high density foam covered with a canvas or leather or similar cover. Perhaps Chris at Badger Coachworks could make up a cover if you could source a rollbar, and some foam. Or get a group together and re-make the stock one!
Old November 5th, 2012, 07:42 AM
Exmoore manufactures a cover for the roll cage foam, Macker. They're on here in the vendors section.
Old November 5th, 2012, 08:33 AM
draaronr's Avatar
draaronr
Here
LR3
please link this, I don't see it
Old November 5th, 2012, 10:35 AM
I think their name is ExmoorUSA or something like that on here. We don't have Internet at work so I can't do the username auto populate thin in this app. Just search all the threads they started and it's in one of those. Of call SafariHP. It looked pretty slick.
Old November 5th, 2012, 11:25 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Here: http://www.defendersource.com/forum/...d.php?p=356294
Old November 6th, 2012, 12:28 PM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
I can get the rear roll bar with both cant rails delivered to my shop for $2500.00, this does not include the alpine bar.
Badger Coachworks
508-394-2680
Sew on and sew forth...
Old November 6th, 2012, 01:37 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
That's good info Chris, are you able to get a b hoop? Thanks
Old November 6th, 2012, 02:05 PM
CDeWan
Clay DeWan
5.3L beastie
C hoop
I took my C hoop to a fab shop and they made a copy of it in tubing so I could run a roof top tent. See the technical section under roof top tent or shoot me a PM and I can send you pics of how it turned out. I am still running my factory tickford with the steel c hoop without any problems.
Old November 8th, 2012, 08:24 AM
Defender50th's Avatar
Defender50th
James
'94 NAS AA Yellow
I have a brand new genuine C hoop and cantrail kit to convert a fastback to full cage. Give me a PM and we might be able to do a deal.
James
Old December 5th, 2012, 03:42 AM
sro
Sam Odio
2008 LR2
So I just got James' C hoop (thanks) however based on the design it appears I need some sort of bar to connect the c-hoop to the frame (through the tub). I'm judging this by holes in the tub that seem to accomodate such a bar and the fact that if one didn't exist, a c-hoop bolted onto the capping/tub doesn't seem very robust in a roll-over.
Does anyone know what I'm talking about? Does such a bar exist?
Old December 5th, 2012, 05:05 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Didyou remove your rear speaker housing? If you look in there you should be able to see if you have the part of the cage that goes from the frame to the capping.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 5th, 2012, 05:12 PM
sro
Sam Odio
2008 LR2
I did remove the speaker housing. There was nothing behind it.
Old December 5th, 2012, 05:53 PM
lordhelemt's Avatar
lordhelemt
Paul
Looks like you'll need that part. Sorry but I don't know the part # for that piece.
Old December 5th, 2012, 05:57 PM
you don't have internet at work???
roll bar
needed: roll bar parts, tailgate, soft top bstraw Wanted 3 March 21st, 2006 10:01 AM
D-90 Roll Bar Pads roverboy For Sale - Parts 2 November 16th, 2005 10:28 AM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
roll bar end caps mpodgorski For Sale - Parts 2 July 9th, 2004 06:09 PM
Rear roll bar pendy Wanted 0 June 17th, 2004 01:10 AM
