Rivits for cappings - Page 2 - Defender Source
Old February 4th, 2010, 12:04 PM
RDS had them as did LR West Chester I think I bought 2 bags from both. I paid 35 cents or so each and had to buy by the bag (I forget maybe 50 to a bag???) UK might work too as shipping would probably be cheap but make sure to get genuine.
edit: 50 to a bag
George sells them for 50cents each
http://www.roversdownsouth.com/body.htm very last thing on the bottom. PN 78248
Uk is expensive, but, they list the size (which I have seen elsewhere as 35mm)
Sealed pop rivet 3/16" x 9/32" long.
http://www.lrseries.com/shop/product...m.html?limit=0
This seems the closest from mcmaster:
http://www.mcmaster.com/#97524a033/=5o8h7m
97524A033
I can't remember if the mandel on the rover ones is alum or steel. This one is alum.
Old February 4th, 2010, 02:12 PM
Originally Posted by TDI Guy View Post
I must admit... NOTHING Looks better then the LR rivets. THey have a different head on them then anything else you can find... I have even used them on other projects cause they are high quality and nice looking too.
Do you mean for the pop rivets or this kind?
http://www.roverhaul.com/galleries/galvtrim
I'm going to need some of these for the roof work. Anyone have a good source for these (and the tools)?
97524A033
Thanks Ron. I'm pretty sure they are all aluminum after drilling out a gazillion of them :D
I think I'll go with mcmaster on this since this is for my trailer and I can't bring myself to spend 50c on each. I'll likely need a couple of different depths but this gives me a great start, thanks!
Old February 4th, 2010, 02:14 PM
In another thread mike says they are not 3/16ths.
Old February 4th, 2010, 08:08 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I used 3/16s all over mine and it's a close match. Charles, for your project I wouldn't worry about an exact match IMHO.
Semper Fi!
Old February 4th, 2010, 08:11 PM
Agreed. Doesn't hurt getting the right sizes if I can though (and would like the use those big solid ones on parts of the roof).
Old February 6th, 2010, 09:04 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
What tools are you guys using to squeeze them and where
are you getting those tools ?
- Charles Eames
Old February 6th, 2010, 10:33 AM
I have a hand pop riveter as well as a air based one (which seemed to jam too easy last time I used it). Those big headed solid ones require a tool thats like a punch with a hollowed out end that you strike to compress the rivet.
Old February 6th, 2010, 03:18 PM
Rivet gun from sears. Hand operated. I use a block of wood under the handle to squeeze it as the rover ones are hard to pull through.
Old March 3rd, 2010, 10:41 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Charles,
Get them from McMaster Carr 3/16" domed, rivets. Here is the link again http://www.mcmaster.com/#closed-end-...rivets/=62cfey I have used LR rivets and these and the only difference is the LR ones cost more. Remember LR buys them like you and me. They don't make them. They are nothing special. Make sure you get aluminum rivet with aluminum mandrel. Measure the thickness of the material your using but most likely 1/4" to 3/8" grip range. Don't pay the big money. $11. per box of 100
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old March 4th, 2010, 07:40 AM
I have rivets in genuine parts packaging that have steel mandrels. They give alot more compression between the peices being joined. Sometimes the alloy-mandreled ones break off before the two pieces are even touching. Though to be fair that is what I usually buy anyway.
Originally Posted by roverx View Post
Charles,
Noise control ttrover Defender Technical Discussions 37 November 29th, 2011 09:21 PM
» Defender Registry
GRNWOLF
GRNWOLF
Bella
D110DC
Add your Defender
