Riveted captive Nut for seat frame - Defender Source
Old July 8th, 2012, 01:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
Not sure the proper name but I was removing one of my seats and one of the captive nut (riveted plate) in the seat box broke.
Anyone have an extra or know the part number?
Old July 10th, 2012, 05:24 PM
Just use a nut. You can get to the other side through the battery box. Those nuts are crap.
Old July 10th, 2012, 05:34 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Are those the same red/orange plastic ones that are on the floor boards and transmission tunnel? If so, I have some I could send out.
Old July 10th, 2012, 05:38 PM
No, they are different.
Old July 10th, 2012, 06:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
I used a big washer and a nut. I would think you need a big washer or the plate so in the case of an accident the seat doesn't rip out. There is one that I had trouble with that I almost either had to remove the center console to get to. Going under the truck the transmission is in the way. Of course I have a tuffy so removing it would be a pain as well. Anyway I got it straight.
thanks
Old July 10th, 2012, 06:23 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I had one break so I welded a nut on a 3x3 1/8 plate and riveted it in four places instead of the two cheesy rivets it came with. Did it break or did the rivets just pop out
Old July 10th, 2012, 06:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
Bolt was frozen and when I went to remove it the rivet sheared off.
Old July 10th, 2012, 06:59 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
If I would of gotten into this thread earlier enough, I would of said IB FIJ SAYS TO USE NUTS.
Robert Deniro
ALQ710020 Bumper Captive Nut Block jefhuf Wanted 4 October 23rd, 2011 11:03 AM
ST b-pillar diagonal support captive nut plates dave_lucas Wanted 12 September 9th, 2011 02:57 PM
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
captive nut for wing intake cover Overlander Defender Technical Discussions 3 July 20th, 2008 11:51 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
