RHD drop pitman arm for d90 - Defender Source
Old June 9th, 2014, 01:50 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Need a replacement pitman arm for a RHD 90. I know there are at least two different types depending on the steering gear. Unfortunately I don't know which one I need or what the difference between them is.
Old June 9th, 2014, 02:13 PM
jafir's Avatar
jafir
Jafir Elkurd
There should be a plate on the box that tells the brand. All I've ever seen have been adwest boxes, but I'm not that experienced with defenders. The adwest boxes use part number STC1044 which SS to QFW000020.
If it's a gemmer box it uses RTC6398
Also, Will Tillery had the best prices when I was looking for one.
Old June 9th, 2014, 02:32 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
What year is the truck?
Petrol or diesel?
Old June 9th, 2014, 02:49 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Originally Posted by Mybluett View Post
What year is the truck? Petrol or diesel?
It's a 1995 more or less 300tdi
Old June 9th, 2014, 02:53 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Box is probably an Adwest - correct drop arm part number is STC887
we can supply as an OEM or aftermarket
Old June 9th, 2014, 02:59 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Box is probably an Adwest - correct drop arm part number is STC887 we can supply as an OEM or aftermarket
What is the damage for an aftermarket arm w/ball joint?
Old June 9th, 2014, 03:09 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
My bad - thats the box part number - correct part numbers below
drop arm is STC1044 - updated part number is QFW000020
Cost is $38 plus shipping
Old June 9th, 2014, 03:19 PM
jafir's Avatar
jafir
Jafir Elkurd
That's a great price too.
Old June 9th, 2014, 04:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I could be wrong but the Disco style can be run left or right side. I have one if you want to run it TRE style.
Old June 9th, 2014, 04:43 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
My bad - thats the box part number - correct part numbers below drop arm is STC1044 - updated part number is QFW000020 Cost is $38 plus shipping
How do I place a order with you? I didn't see this part on your website.
I would also need a new pitman arm lock washer and that bottom dust shield for the steering box as both got pretty jacked up in removal.
------ Follow up post added June 9th, 2014 04:44 PM ------
I thought they looked the same but I didn't want to pull the one off my disco to compare teeth to teeth.
Old June 9th, 2014, 04:58 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
They do look a lot alike. That's why I wasn't 100% sure. I can't get the one off my LHD Adwest PS Box otherwise I would compare teeth to teeth. Maybe someone else on here knows for sure.
D1/LHD drop arm on a RHD D90? Howski Defender Technical Discussions 3 September 4th, 2013 05:22 PM
Pitman/Drop Arm with new rebuild kit - $60 nopants For Sale - Parts 2 July 13th, 2011 06:42 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
