RHD Bulkhead Footwell Repair Panels - Defender Source
Old September 26th, 2016, 01:57 PM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
I know I can order these from YRM but just wanted to check and see if anyone had a set of these laying around or didn't end up using before I go ahead and order from across the pond..
LHS Footwell Repair Panel
RHS Footwell Repair Panel
Old September 26th, 2016, 02:00 PM
The Dro
Dro
1988 Ninety
Call Erik at Lucky 8
Old September 26th, 2016, 03:02 PM
Naplm00
Matthew
I had mine made for less than the yrm pieces, went to a ducting/sheet metal shop with cardboard templates... This will only work if the bottoms are rusty not the sides
Edit; this was also when the gbp was strong. Got them done at Altoona near little ferry nj
Old September 29th, 2016, 05:23 PM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Thanks for the help..
Just ordered from Erik at Lucky 8
Old September 29th, 2016, 05:40 PM
Naplm00
Matthew
No worries, to make fitting the floor panels easy have them halfway bolted in when you are welding the footwells so they line up
bulkhead, footwell, panels, rhd
Want to buy RHD footwell repair panel RS 1sogdusm Wanted 2 April 14th, 2013 05:46 PM
Where does one procure bulkhead footwell repair panels? evilfij Defender Technical Discussions 13 January 12th, 2010 02:37 PM
Removing LH wing / Fender on '83 for bulkhead footwell repair... turbodave Defender Technical Discussions 5 May 25th, 2009 04:16 PM
Drivers side bulkhead footwell repair panel for left hand drive D-90 Tyler Wirken Wanted 4 September 25th, 2008 12:26 AM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
