Relatively recent rebuilt 3.9 or 4.0 - Defender Source
Old August 24th, 2010, 02:46 PM
bd90
94 Arles Blue #1644
I just learned that my mechanic cannot find anyone who rebuilds LR 3.9's. Engine is still running but a bearing or wrist pin is starting to make noise. A new 4.0 short block is $3200 I am told. Guess I should try for a 4.0 because of the availability of parts is greater.
Old August 24th, 2010, 02:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
if you are going this route get a 4.6
Old August 24th, 2010, 03:03 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I think i know of a 20k mile 3.9 pulled out of a 1994 defenderr. located in me.
Old August 24th, 2010, 03:04 PM
Yes, buy a 4.6 short block or go cheap and just get a used motor and swap it in.
Also, run the motor until it siezes. I sort of doubt you have a true bearing or wrist pin failure.
Old August 25th, 2010, 11:59 AM
bd90
94 Arles Blue #1644
Will the 4.6 work with the existing ECU?
Mechanic says it's definitely in the bottom end, what else could be making that ticking noise. The noise only starts when it reaches normal operating temp.
Now I feel snake bit with the 3.9. I can't see going that route unless it's new. I'm tempted but it just doesn't seem like the smart thing to do. I'm starting to see that the 3.9 is a dinosaur.
Old August 25th, 2010, 12:51 PM
Just use a 4.2 chip out of a 93-95 RRC LWB. ~$100. It will work fine with the stock ECU though.
Old August 25th, 2010, 12:56 PM
rovertrader's Avatar
rovertrader
Dale
if you think the 3.9 is bad, wait til you get a 4.0. As stated above, do a 3.9 or 4.6- or better yet a 4.2 if you can find one.
Old August 25th, 2010, 01:01 PM
Someone posted a 4.2 for sale recently
Originally Posted by pendy
I'm here for the D's
Old August 25th, 2010, 01:19 PM
Could be cam bearings. Like I said, run it until it siezes.
3.9 V-belt, 4.2 serp 4.0 Gems pushngo For Sale - Parts 2 July 1st, 2010 12:16 PM
Ceramic Coated Manifolds, 3.9, 4.0, 4.2 Method PHX For Sale - Parts 36 September 18th, 2008 03:11 PM
3.9 versus 4.0 The Wizard Defender Technical Discussions 11 January 31st, 2008 11:56 AM
Visual differences between 3.9 & 4.0 Neil McCauley Defender Technical Discussions 11 November 17th, 2006 11:53 AM
4.0 short blocks $1200 shipped evilfij For Sale - Parts 2 November 7th, 2003 10:57 PM
