Recovery hoop - Defender Source
Old February 9th, 2016, 09:58 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Recovery hoop
Looking for those recovery hoops that go in place of vehicle tie down loop. This is for classic RR but I think military defenders came w them front n back.
Appreciate any leads
Old February 9th, 2016, 10:00 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
TOW RING MILITARY STYLE DEFENDER w/HRDWR, PLK0211 - Rovers North - Classic Land Rover Parts
Old February 9th, 2016, 10:01 AM
Zack the force is strong with you today...
Old February 9th, 2016, 10:09 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I have to attribute that to my weekend...it was solid.
Old February 9th, 2016, 10:11 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Good fishing clears your mind?
Rent my
Old February 9th, 2016, 10:23 AM
Just keep in mind they are not designed nor ever intended for recovery.
Old February 9th, 2016, 10:31 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
As Red90 said, but think when your suck in the mud up to your axles where is that so called recovery hitch now? Get something up higher
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 9th, 2016, 12:36 PM
so whats the verdict then? half the 'experts' out there say bumper mounted recovery are never good enough. only acceptable place is frame. and now we're saying jate rings aren't good enough?
Mark Kellgren
KM4BOR
Old February 9th, 2016, 12:43 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Depends on the bumper, depends on the fasteners.
A dual grade 8 bolted recovery point to the chassis is perfectly acceptable. A properly plated bumper mounted point is acceptable. There are plenty of acceptable points
Old February 9th, 2016, 12:52 PM
I have an ARB, and completely agree on keeping it up high. thoughts on adding recovery points (of proper quality) to an ARB?
there's a lot of self-proclaimed experts out on the web that can't agree on the color of the sky, let alone recovery points for an ARB.
Mark Kellgren
KM4BOR
Old February 9th, 2016, 12:55 PM
The bumper needs to be suitably designed for the recovery point(s). With a a Defender chassis, IMO, it should be attached to more than just the four stock locations. At some point in the design, someone adequately qualified in structural design should review the system.
Old February 9th, 2016, 01:00 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You could use the Dixon bates unit with a larger backing plate.
TOW JAW ASSM 7,700 LB CAMEL TROPHY STYLE, RNF408, TJA3500 - Rovers North - Classic Land Rover Parts
Old February 9th, 2016, 01:26 PM
I had on of those on the ARB of my old D1. Didn't like them. I was back in AZ then, and the Dixon's would constantly F' with my approach angle out in the red rock and get me hung up.
I like the low profile swivels. not sure if an ARB is strong enough to mount them. I"m looking for real strength in recovery scenarios, not bling (not that I think Dixon's are bling, but rather for any follow on advice).
Mark Kellgren
KM4BOR
Old February 9th, 2016, 01:32 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
ARB is plenty strong, as long as you use a LARGE backing plate.
Old February 9th, 2016, 02:06 PM
Boom! Actionable information from Z and 3D.
Mark Kellgren
KM4BOR
Old February 9th, 2016, 02:57 PM
Ive got (and recommend) R&P shackle mounts. But ive got a custom bumper mounted with grade 8 hardware.
http://www.defendersource.com/forum/...tml#post327099
-Jeff
no backing plate ?
Old February 10th, 2016, 08:09 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I got a set if you want'm? $50+shipping
Old February 10th, 2016, 11:43 PM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Are these genuine LR JATE rings? If so, I'm 2nd in line behind OP if he doesn't follow up.
And JATE rings are certainly proper recovery points if used correctly.
Old February 11th, 2016, 08:26 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
They are Genuine!
cover, hoop
Front Recovery Points loykd Defender Technical Discussions 48 May 7th, 2010 09:30 PM
Crazy Pic and Story of Recovery Accident priest944 Misc. Chit-Chat 7 March 23rd, 2005 12:19 PM
Recovery/ tow strap questions... mspell Defender Technical Discussions 13 February 22nd, 2005 02:54 PM
ARB Recovery Point TurkD90 Defender Technical Discussions 2 December 3rd, 2004 10:54 PM
Rear recovery point souza Defender Technical Discussions 33 September 22nd, 2004 11:41 AM
